i don't know what other will think but i don't think it's messed up. personally i think it's pretty damn inventive.
Printable View
or even if i could disable the hover effect all together.that would work too.
ok.I have never used stylebuilder before.so im going to give it a try.I brought up the hud launch msstyle.but im not quite exactley sure what to delete or how to go about it.It seems the "remove propery" is greyed out or black under every thing i click on under "ListItem".I think i may not be clicking on the right thing maybe? Just a quick how to and what would be greatly appreciated.Thankyou for this.cant wait to try it once i figure it out.
Attachment 75176
Sure, that version of WSB that you're using is outdated, you can still use it, but you might want to grab a copy of one of Mr GRiM's custom import scripts build here for updated class maps (it works fine on any Windows OS):
https://virtualcustoms.net/showthread.php/70828-Custom-Class-Maps-and-Import-Scripts-for-Windows-10-TH2-RS1
What you can do is hit export on one of the list view images, open the image in PS, delete the image itself so it's just a transparent layer with no graphic, and save the image. Now import that transparent image for all of the tree sections under ListItem, enter testing mode and if everything is good than save your theme and replace it in \Resources\Themes and reapply your theme from the personalization pane.
