2 Attachment(s)
Zero-G
For November Update only!! TH2
Attachment 71531
This is the first time this version of the theme has been posted, it's based on the original concept using the white explorer but using the all glass start menu.
Enjoy :smile:
https://virtualcustoms.net/attachment...id=70715&stc=1
StartIsBack ++1.2
- Minor changes:
UxStyle
Not fully supported on TH2
