great as always gsw953
Printable View
Thx for the reply and the welcome :), i manage to make everything black but i dont have the transparency at explorer. I only have transparency at taskbar.
gsw uses a program called system transparency for that. I am currently using AeroGlass and have noticed a few small issues with it on RS1. So I may temporarily switch to system transparency if it currently works better. But once you have system transparency set properly it should work fine.
The one included in here https://virtualcustoms.net/showthread...a-Redstone-One
953 i found my copy FINALLY lol . worked out though, cause it forced me to rethink how i have themeing items organized. i have you theme up and running in vm now. in order uxstyle, theme bypasser, one, sib, dropped your theme in the themes folder and tested, worked perfect. then added and tweaked system transparency to my liking. have also tested one of grims black themes and perfect as well.
