Yes I know. I have already downloaded a bunch if them. Thank you for the awesome themes.
Printable View
Hi, Awsome theme and thank you very much for all the themes you made and ported over to win 10.
I am pretty sure its impossible to brink a pc just by messing about with the OS. Brink is mostly on smart phones. If pc dont work right then we can restore it or reinstall windows. PC's as far as i know can only get brinked if you screw up the bios...
Quostion : Have i misunderstood what is ment by brink ?
To "brick" your system is possible when messing with custom themes, cause you have to read and follow the "how to succeed.."
Look very carefully when you read this for an example:For November Update only!! TH2 AKA 1511 AKA 10586 Only!!
That means if you try using this theme on anything else, you computer will be a "brick" no doubt!!
So the most important thing is to make a complete backup of the drive where your OS is installed..and making a restore point is not a bad idea either..
Then you can mess things up just as you like and even get some experience too ;)
COOL COOL
