2 Attachment(s)
Alien Return Red by Alienbyte
Alienbyte
Alien Return Red theme by ✧☣ ДŁƗɆȠƁƳƬЄ™☣✧
Windows 10 RS2 1703 15063
Windows 10 RS3 1709 16299
Windows 10 RS4 1803 17134
Windows 10 RS5 1809 17763
Special thanks to Dark Knight
https://virtualcustoms.net/attachment...3&d=1316585287
https://i66.tinypic.com/34ot3sl.png
https://i65.tinypic.com/hvaq20.png
https://i67.tinypic.com/2zh387d.png
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= UxTheme service hook - Visual Theme Signature Bypass
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== OldNewExplorer is the Windows 10 (and Windows 8.1, and 8)
https://virtualcustoms.net/attachment...5&d=1472576019
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Full taskbar skinning!
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Ability to reduce resource usage by disabling newer Start menu and Cortana processes from prelaunching
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Ability to use adequately sized (32x32) large icons and larger start menu button on taskbar
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Modern blur, drop shadow and immersive context menus for start menu
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== This utility returns the complete glass effect into windows frames.
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Fully native including MSStyle themes and DWM API compatibility
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Winaero Tweaker is an all-in-one application which will include most options available in the free Winaero apps
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Apply System Metrics included in the "Extras" folder and logout or reboot
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Select the Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first!
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Copy a Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.
| Please make sure you download the correct theme file according to your operating system version! | |
https://virtualcustoms.net/attachment...2&d=1318717506
