5 Attachment(s)
AC/DC Rock or Bust Mastering Works For Windows 10 RS5 and RS6
An Original Windows 7 Theme Created By Razorsedge
For Windows 10 RS5 (1809) and Windows 10 Spring 2019 Update RS6 (1903)
Ported By Dark Knight
I present to you .....
AC/DC Rock or Bust
Attachment 81193
Attachment 81194
Attachment 81195
How To:
You'll need your system patched with UXThemePatcher.or ThemeSignatureBypass
AeroGlass is also recommended for this theme as it features a good amount of transparency.
Links to required software:
StartIsBack
OldNewExplorer
UltraUXThemePatcher
Aero Glass (ThemeSignatureBypass tool located on the same page at the bottom)
Information
| It took some time to port this theme only for the reason is that for some reason WSB for 1809 does not seem to want to port the Taskband Extended UI images properly, I don't know if this is an issue with WSB, SIB or the shellstyle file for 1809. I say this because Razorsedge had used two different images on the Taskband Edtended UI images, I was forced to use only one as it seems that something was preventing me from using both. This is an amazing theme and I hope I did it justice and everyone enjoys it ! | |
| This theme is for use only on Windows 10 RS5 V1809 - I take no responsibility for any user that downloads and installs on any other version of Windows other than for it's intended use | |
