It honestly isn't that complicated, renaming one file, making a new folder to put all your themes in, editing the .theme files with notepad++ takes a few seconds and your done.
dhjohns cool. may i suggest that you don't include any themes in it. this way if it needs updating later for any reason it will be easier to do.
GRiM do you think this is better done on a clean install of 10586? the reason i ask is from the time i put in my usb key to install windows till i have my last app installed it only takes about 5 hours.
this is what i end up with after trying this method , uninstalled both UltraUXThemePatcher_3.0.4.exe and UxStyle_0242_x86_x64_preview.exe
i have OldNewExplorer applied and set to the image post above
Attachment 71795
start is back is not seeing the new way as you can see in the image .
edit: I was able to get things working by reinstalling UxStyle_0242_x86_x64_preview
OK, I have everything working properly. As of this moment, I do not have the UXThemeSignatureBypass, but I DO have the UxStyle.exe installed. It seems as if the dll files in /Windows/System32 are not replaced properly. I do not have an all in one ready right now, but I got everything working in safe mode. You could give it a try in regular mode if you want. I deleted the themeui.dll.bak, uxinit.dll.bak, and uxtheme.dll.bak files. Then I ran THIS code as administrator. I named it as a .cmd file.I put the pauses in to make sure everything was copied, and renamed correctly. Then I pasted the original files into the /Windows/System32 folder. Here they are if you do not have them. https://mega.nz/#!0YYihRDS!mWsuYod6e...rjIWgTPxjsIE88 For some reason I had to restart twice, but I think that had to do with all my monitors not being recognized.Code:takeown /F %SYSTEMROOT%\System32\themeui.dllicacls %SYSTEMROOT%\System32\themeui.dll /grant "Everyone":F
REN %SYSTEMROOT%\System32\themeui.dll themeui.dll.bak
pause
takeown /F %SYSTEMROOT%\System32\uxinit.dll
icacls %SYSTEMROOT%\System32\uxinit.dll /grant "Everyone":F
REN %SYSTEMROOT%\System32\uxinit.dll uxinit.dll.bak
pause
takeown /F %SYSTEMROOT%\System32\uxtheme.dll
icacls %SYSTEMROOT%\System32\uxtheme.dll /grant "Everyone":F
REN %SYSTEMROOT%\System32\uxtheme.dll uxtheme.dll.bak
pause
Still i can't made it to work.. Can you post some screenshots with your files inside the resource folders?
