Results 1 to 6 of 41
August 30th, 2009 09:28 PM #1
List of Software you might need for Customizing Your OS
This is a list of software for Customizing your Windows OS, first post will be updated as we go.
1. IconPackager
IconPackager is a program that allows users to change nearly all of their Windows icons at once by applying "packages" of icons. A package of icons contains icons to replace most of the common icons on your Windows PC.
9XKfc6fDuKj91fLCd5SgLkOQb3Cj2r3Jnr-CpmYmd41rUlNRP9QiFL7DURW87pGlHDfqbtU/software/11008169/10031210/3/iconpackager_public.exe?lop=link&ptype=1901&ontid=2195&siteId=4&edId=3&spi=7c73e3c4ecfae40878c8bc733aaba231&pid=11008169&psid=10031210" target="_new">
2. WindowBlinds
WindowBlinds is a one-of-a-kind utility that allows Windows users to completely change the look and feel of the Windows interface by applying a new skin.
Supports Windows 7, Vista, and XP
3. Desk Scapes
Stardock DeskScapes is a program that allows users to have animated wallpaper on their Windows XP or Vista desktop. It supports playing video as animated wallpaper, dynamically generated content as animated wallpaper, and more.
For Vista Ultamate
4. Adobe CS4 (30 day Trial)
Adobe Photoshop CS4 software is a powerful, professional-quality image editor
5. Restorator
Restorator is an award-winning utility to edit windows resources in applications and their components, e.g. files with .exe, .dll, .res, .rc, .dcr, extension (see PE files and RES files).
Change, add, remove resources such as text, images, icons, sounds, videos, version, dialogs and menus in almost all programs.
Restorator is used for translation/localization, customization, design improvement and development.
This resource editor comes with an intuitive user-interface, complete documentation with many examples and prompt user support in the discussion forums or via email.
6. Paint.NET
Paint.NET is designed to be accessible and simple for most users while still allowing powerful and sophisticated operations to be performed on an image.
3.5 Alpha Build.
7.IcoFX
IcoFX is an award winning freeware icon editor. It is an all-in-one solution for icon creation, extraction and editing. It is designed to work with Windows XP, Windows Vista, Windows 7 and Macintosh icons supporting transparency.
8. IconViewer
IconViewer is a freeware product developed by Bot Productions. It is a utility that allows you to view the icons contained within files, such as executable files and dynamic link libraries (DLLs).
9. Resourcer
A ResHacker clone developed as a testbed for Anolis.Core and to replace ResHacker (because ResHacker doesn't support x64, XN Resource Editor (ResHacker's spiritual sequel) doesn't support multiple-language resources and crashes a lot, and other utilities rest cost actual money. It has a powerful yet simplified UI that doesn't duplicate commands or confuse the users with special-case handlers (which ResHacker and XN have in spades).
10. VistaGlazz
VistaGlazz 2.0: Windows 7 & XP SP3
We’ve been working on a new product for quite some time and we would like to present it to you on this fine day. Also, we’d like to quit work and drink cocktails on a tropical island for the rest of our lives. Anyway, this is all not going to happen. Or at least, not today.
Don’t worry though, we’ve heard your requests for a SevenGlazz, and we’re proud to present VistaGlazz 2! We’re emotionally attached to the old name
The new VistaGlazz supports the KB971029 update, but also enables style customization for Windows XP SP3 and Windows 7 (both 32 and 64 bit)!
11. Logon Screen Rotator (2.1.0.2)
Windows 7 Logon Screen Rotator is a free application that will change the logon background image to an image of your choosing and also at a time you select. Current options include: each day, each logon and each computer lock.
You may choose individual images or folders of images (which will be monitored by the application for changes) for the program to select random images from.
If you only wish to change the image once, this is also possible.
12. WinBubble 1.76, "Customization and Tweaks, Not Just for Geek's But For ALL" (Free)
Two Clicks, "Check and Apply"
In just two clicks, WinBubble will help you to Customize and Tweak your Windows Vista easily. Its features cover Customization, Security and Optimization.
13. Resource Hacker 3.5.2 beta
"Resource Hacker is a freeware utility to view, modify, rename, add,
delete and extract resources in 32bit Windows executables and resource
files (*.res). It incorporates an internal resource script compiler
and decompiler and works on Win95, Win98, WinME, WinNT, Win2000 and
WinXP (...).
I've just updated Resource HackerTM to open (ie decompile/recompile)
these files too. This new version also displays PNG image
resources.(...)"
14. CursorFX
CursorFX users can create and use cursors that look and feel far superior to anything you've ever seen before! Best of all, it's really easy to create your own super-charged cursors! It integrates into the standard Mouse interface of Windows and is easy to turn on and off as you need.
15. Librarian: A Library Manager for Windows 7
Librarian is an excellent piece of software created by our friend "Happy Bulldozer aka hb860". It allows you easily tweak Libraries in Windows 7.
It is a multi-language application which allows you to:
* Create a new library with any folder(s) inside
* Change library's icon through standard Windows dialog
* Rename library
* Change content type of new or current library
* Change "default save location" option
* Change "Show in Navigation Pane" option
* Show library as XML
16. Axialis CursorWorkshop
Create hi-quality cursors for Windows® and web sites
With CursorWorkshop™ make your own hi-quality static and animated cursors for Windows and Web sites.
The new generation of cursors uses variable transparency (alpha channel). This feature permits creating beautiful cursors with smooth borders and shadows. You need a professional tool to create such cursors. Axialis CursorWorkshop™ has been designed with one goal in mind: "Quality".
Enjoy the powerful editor which permits creating the various image formats of a cursor from an original drawing without quality loss.
The cursors can be created to customize Windows or enhance applications. You can also add your own cursors in your web sites.
Download a 30 Day Trial
17. Axialis IconWorkshop™
Create hi-quality icons for all systems: Windows, MacOS, Unix
With IconWorkshop™ make your own icons for Windows®, MacOS® and Unix®. It creates Windows® icons up to 256x256 for Windows Vista™ and Macintosh® icons up to 512x512 for Leopard (MacOS® 10.5). Unix® uses PNG icons. IconWorkshop creates PNG images with alpha channel in a few clicks including from existing Windows® and Mac OS® icons.
The new generation of icons uses variable transparency (alpha channel). This feature permits creating beautiful icons with smooth borders and shadows. You need a professional tool to create such icons. Axialis IconWorkshop™ has been designed with one goal in mind: "Icon Quality".
Enjoy the powerful editor which permits creating the various image formats of an icon from an original drawing without quality loss.
Download a 30 day trial
18. Axialis Screensaver Producer
Create all kinds of screensavers from Sprites
Creating state-of-art screensavers with sprites (animated objects moving on screen) has never been easier. For example, you'll be able to create in minutes a cool screensaver with your company logo bouncing on screen.
Images with transparency (including alpha-channel) are supported. Several options are available: Bouncing on the screen borders, realistic collisions between objects and more...
19. DAZ Studio 3
DAZ Studio is a free, feature rich 3D figure design and 3D animation tool that enables anyone to create stunning digital imagery. This is the perfect tool to design unique digital art and animation using virtual people, animals, props, vehicles, accessories, environments and more. Simply select your subject and/or setting, arrange accessories, setup lighting, and begin creating beautiful artwork.
20. Gimp 2.6
GIMP is the GNU Image Manipulation Program. It is a freely distributed piece of software for such tasks as photo retouching, image composition and image authoring. It works on many operating systems, in many languages. (more...)
customizing a windows iso
By ZzKePhAzZ in forum General DiscussionReplies: 0Last Post: October 23rd, 2020, 10:06 PM -
Customizing Google
By LoneStar in forum General Windows 7 CustomizationReplies: 0Last Post: April 26th, 2014, 05:11 AM -
Customizing open list of programs
By Bourne in forum General Windows 8 CustomizationReplies: 1Last Post: October 17th, 2013, 09:40 PM -
Customizing 7 to no end.
By Mordax in forum General Windows 7 CustomizationReplies: 29Last Post: May 26th, 2013, 05:09 PM -
BitDefender tops AV-Test list of security software for 2010
By razorsedge in forum News & ReviewsReplies: 0Last Post: January 29th, 2011, 03:59 AM
looking for help with...
