Results 1 to 6 of 6
Thread: Zoom Effect Share
    Mr GRiM is offline
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,537
    513 Thread(s)
    Zoom Effect
    The first thing you do is start with a photo.
    Choose the eliptical marquee tool from the toolbox.
    Make a selection on the photo, as shown.
    Tip: Hold the space bar to reposition the selection as you are drawing it.
    Now, it's important to feather the selection. If you don't the effect will be too harsh and obvious. The feather creates a soft edge and a smooth transition to the blurred areas.
    Select>Modify>Feather
    (Photoshop CS3 and CS4 / before that it was Select>Feather)
    Depending on the resolution you will change the size of the feather. This was low res so I used 15.
    Right now you have a selection around the center of the image. We want to select everything BUT the center.
    Choose Select>Inverse or Ctrl-Shift-I (Cmd-Shift-I on Mac)
    You should see the selection go around the edge of your page now
    This is where the effect happens.
    Choose Filter>Blur>Radial Blur
    Choose Zoom as the method
    Select Good for quality (Best takes forever with little improvement in quality)
    Choose your amount to suit. For a heavier blur use 100. You might have to test it and undo a few times to get exactly what looks best on your image. In this case I used 55.
    And here we have the final result. Changing the feather and the blur amount will change the effect. Experiment with different shaped selections and different amounts of blur. In some cases you may want to apply the blur more than once.
    Note to Advanced users: best wayto do this is to create a smart object, run a smart filter /and then mask the filter, that way the file size doesn't increase and you can use a raw file.
    However I wanted to keep it simple for the tut.
    Here's an example of the effect in-camera.
    I used a slower shutter speed and pulled the lens in as I took the shot. Start moving th lens before clicking the shutter, this way you will get a smoother movement.
    Find more tutorials like this @ [Only registered and activated users can see links. ]
    vierasniper is offline
    Mar 2010
    1
    Re: Zoom Effect
    Dude Wicked tutorial!!! used it in a pic of my cats. haha awesome stuff!!
    osman_2626 is offline
    Feb 2010
    116
    Re: Zoom Effect
    thanks
    Erny
    Guest
    Re: Zoom Effect
    graet efect.
    dareckibmw is offline
    Oct 2009
    63
    5 Thread(s)
    Re: Zoom Effect
    Yep, awesome tutorial!
    1600x1200 here [Only registered and activated users can see links. ]
    ZeroKnight is offline
    Aug 2010
    20
    15
    Re: Zoom Effect
    Nice man, thanks!
    Quick question. You mentioned it at the end, and I've seen it in the menu before...but what is a "Smart Object" in Ps?
  1. Samsung Galaxy S4 Zoom Priced for the United Kingdom
    Last Post: 07-01-2013, 01:19 PM
  2. Effect Water
    By Letícia® in forum Wallpapers Posted by Leticia
    Last Post: 05-08-2012, 01:12 PM
  3. Mass Effect 2
    By mauam in forum Screen Savers & Dream Scenes
    Last Post: 03-16-2012, 09:27 PM
  4. Zoom for AIMP2 player by ~memo-se
    By razorsedge in forum AIMP2
    Last Post: 02-01-2011, 04:17 AM
