Thread: QuickSilver Theme for Windows 7
October 17th, 2009 03:00 PM #1
New Theme for Windows 7, some of this theme used bits from Latoyce RC1.b by ~X3remes https://x3remes.deviantart.com/art/La...RC1-b-61254160, some bits from older themes and some bits are new, so enjoy the new theme and hopefully there will be more to come.
Download
QuickSilver.zip
InformationVery Important!!!
Univeral Theme Patcher
https://virtualcustoms.net/showthread...-Theme-Patcher
UXStyle Core
https://virtualcustoms.net/showthread...cher-0.2.1.1.1Last edited by HaCkthEplAneT; August 12th, 2011 at 06:38 PM.
windows longhorn 4039 plex theme for windows 10 2004
By CSX in forum General Windows 10 CustomizationReplies: 0Last Post: September 30th, 2020, 01:12 AM -
How to make a windows 10 theme in windows style builder ?
By elfenliedtopfan5 in forum General Windows 10 CustomizationReplies: 0Last Post: October 22nd, 2019, 08:35 PM -
By hl2modrift in forum Theme IssuesReplies: 2Last Post: October 30th, 2011, 07:19 AM -
Windows Xp theme defualt for windows 7
By Crusisx in forum Theme RequestsReplies: 0Last Post: October 21st, 2010, 05:17 AM
