Results 7 to 12 of 427
Thread: Dark7 Ultimate Theme for Windows 7 (Final Version)
    Mr GRiM is offline
    Administrator
    5,328
    837 Thread(s)
    One of my first themes, I thought it was pretty Ultimate at the time
    Information
    Very Important!!!
    https://virtualcustoms.net/showthread...-Theme-Patcher
    UXSytle Core
    https://virtualcustoms.net/showthread...cher-0.2.1.1.1
    Information
    To have your taskbar centered like in the image above.
    NOTE
    Taskbar will not display blue bar if you have your options set to never combine.
  1. Gray10 Theme for Windows 1903 version
    By ericleb1187 in forum Windows 10 Theme Help and Support
    Last Post: March 17th, 2020, 05:26 PM
  2. Looking for any windows 10 theme For 1803 Version
    By IsoPack in forum General Windows 10 Customization
    Last Post: August 21st, 2018, 01:28 AM
  3. Ultimate Clean version 3
    By gsw953 in forum gsw953's Windows 7 Themes
    Last Post: March 3rd, 2014, 02:46 PM
  4. Mozilla Firefox 4.0 Final Version will Release in Early 2011
    Last Post: October 28th, 2010, 10:12 PM
