Dark7 Ultimate Theme for Windows 7 (Final Version)
One of my first themes, I thought it was pretty Ultimate at the time
Information
Very Important!!!
Universal Theme Patcher [Only registered and activated users can see links. ]
UXSytle Core [Only registered and activated users can see links. ]
Information
To have your taskbar centered like in the image above.
NOTE
Taskbar will not display blue bar if you have your options set to never combine.
Just found this site. Mr Grimm you have serious skills, these themes are fantastic. I am going to wait until this Dark7 is finished to try to install one though. Hope to see it soon.
My only problems with the theme, other than that you did an amazing job.
and do u think you could pm that start orb at the 6806 size if you have it?
thanks
thanks
That is the reason I am installing x86 on the VM so I can see if I can fix some of these problems on X86.
Which start button do you want, the one I am using?
First post updated with RC2 and now x86 is fully compatible.
wow your amazing.
and can i request maybe a remix of kiilki?
i love that theme and i love your themes so i thought if u 'remixed' it it would be an awesome theme.
thanks
wow your amazing.
thanks
Thanks mate, I will have a go at making something similar to that theme soon.
