Page 1 of 4 1234 LastLast
Results 1 to 8 of 25
Thread: Vista Style Builder version 1.4 Windows 7 Fix Share
    Mr GRiM is offline
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,511
    500 Thread(s)
    Many people are using Windows 7 now and allot of people also have Vista Style builder version 1.4, but what allot of people don't know is that there is a problem when saving themes for Windows 7 and although it appears to work at first, it has a problem when trying to login after a restart and goes into a continuous loop.
    The reason why that happens is unknown but it has something to do with the numbers of the images being changed when saved, instead of starting at image 508 where it should it instead saves the images starting at 10000, this is a bug know on the Vista Style Builder forum and has been fixed for later versions, there is a fix for this little problem though and is very easy to do.
    First go to C:\Users\Your User Name\AppData\Roaming\VistaStyleBuilder\settings.ini and right click on setting.ini and select edit, now paste FirstImageId=508 after [Settings] and save.
    Now the images will be saved starting at 508 and your themes will work correctly.
    lefty1981
    Guest
    Re: Vista Style Builder version 1.4 Windows 7 Fix
    who?
    [MRU]
    num=1
    file1=C:\Windows\Resources\Themes\Aero\aero.msstyles
    [Settings]
    currentSearchType=1
    Mr GRiM is offline
    Bringer of Death
    36
    4,511
    500 Thread(s)
    Quote Originally Posted by lefty1981
    who?
    [MRU]
    num=1
    [Settings]
    currentSearchType=1
    Like this:
    [MRU]
    num=1
    [Settings]
    FirstImageId=508
    currentSearchType=1
    lefty1981
    Guest
    it work!puh thank you very very much!^^
    Psych0t1c is offline
    Nov 2009
    Chester
    25
    305
    8 Thread(s)
    Thanks. I was wondering why this happens.
    VindicationX is offline
    Nov 2009
    1
    Is that what the problem has been? I was about to pull my hair out trying to figure out why when editing a current VS, making only simple color or font changes, the entire theme 'breaks' and seems to default to the basic Aero theme, no matter what I tried. So, this fix should fix that issue?
  7. #7
    Mr GRiM is offline
    Bringer of Death
    36
    4,511
    500 Thread(s)
    Quote Originally Posted by VindicationX
    If you are using version 1.4 then this fix is critical and without it you will have a big headache.
  8. #8
    cloud7 is offline
    Dec 2009
    20
    Thanks for the fix.
  1. Vista Style Builder Theme Design Help
    By kumaramy in forum Miscellaneous questions
    Last Post: 06-06-2013, 06:56 AM
  2. How to make a Visual Style for Windows Vista
    By Mr GRiM in forum Vista Style Builder v1.4 Tutorials
    Last Post: 06-27-2012, 01:36 AM
  3. little problem with vista style builder
    By proto69 in forum Theme Requests
    Last Post: 01-04-2010, 06:43 PM
  4. Help with Vista Style Builder
    By shyamsasindran in forum Software
    Last Post: 12-19-2009, 02:08 PM
