Results 25 to 25 of 25
December 5th, 2009 11:54 AM #1
Vista Style Builder version 1.4 Windows 7 Fix
Many people are using Windows 7 now and allot of people also have Vista Style builder version 1.4, but what allot of people don't know is that there is a problem when saving themes for Windows 7 and although it appears to work at first, it has a problem when trying to login after a restart and goes into a continuous loop.
The reason why that happens is unknown but it has something to do with the numbers of the images being changed when saved, instead of starting at image 508 where it should it instead saves the images starting at 10000, this is a bug know on the Vista Style Builder forum and has been fixed for later versions, there is a fix for this little problem though and is very easy to do.
First go to C:\Users\Your User Name\AppData\Roaming\VistaStyleBuilder\settings.ini and right click on setting.ini and select edit, now paste FirstImageId=508 after [Settings] and save.
Now the images will be saved starting at 508 and your themes will work correctly.
can't move caption buttons in vista style builder
By vexa in forum Windows Style Builder v1.5 TutorialsReplies: 2Last Post: October 1st, 2014, 01:02 PM -
By vexa in forum Windows 7 Theme Help & SupportReplies: 7Last Post: September 27th, 2014, 03:47 PM -
Vista Style Builder Theme Design Help
By kumaramy in forum Miscellaneous questionsReplies: 3Last Post: June 6th, 2013, 06:56 AM -
little problem with vista style builder
By proto69 in forum Theme RequestsReplies: 2Last Post: January 4th, 2010, 06:43 PM -
Help with Vista Style Builder
By shyamsasindran in forum SoftwareReplies: 0Last Post: December 19th, 2009, 02:08 PM
