Thread: Xtreme Red Theme for Windows 7
December 14th, 2009 10:42 AM #1
Update: 29/05/2011
I have updated this theme a bit and made it to use with theme resources changer so you don't need to change any system files any more, I also borrowed a few bits from my Premium theme Poison and a couple of others to give some new life to this theme, I will keep the old versions here as well if anyone wants them, there is only one version for the new theme unlike the old one that had 3 variants, I think this version is more usable then the other 3 combined anyway so don't think it's needed.
Xtreme Red.7z
InformationUpdate 01/02/2013
Added new style with fully blurred Start Menu
X-TREME v3.7z
New clock for use with 7tsp, it will just replace the clock in the timedate.cpl
7tsp_Xtreme_Red_timedate.cpl.7z
If you need to install Theme Resource Changer you can grab it from here https://virtualcustoms.net/showthread...-dll-editing..
Old Styles
[SIZE=4]
There are 2 versions of this theme, Xtreme Red and Xtreme Red 2, the second one has a a few more black areas then the first like the taskmanager and other windows will be black instead of white, the only downside is that some web pages when using IE8 will be very dark although Firefox seems unaffected by that, the only other downside to some using the second theme will be things like Office which will have Black page colours instead of white, although there are probably options to change the page colour in those programs.
Both themes have been tested on X86 and X64 and I haven't seen any major problems, but if you do notice something please post a screen shot and let me know.
Have fun with the new theme and please comment
Please read the notes below on how to have your taskbar centered like in the preview.
Xtreme Red Xtreme Red.7z
Please download the theme file attatched at the bottom of this post if your using Xtreme Red 2, found a problem using black as a window colour but changing the colour to #010101 fixes it, you will notice if you use winrar that the left pane has been changed to a very light colour when it was meant to be turned black, changing the colour to #010101 stops that happening and it turns back to black.
Xtreme Red 2.theme
Attachment 29689
If you want to have the clock a different colour to match the theme like the one above you will need to replace a system file in system32
Attachment 29688
Full Glass Blue Icon pack Download Links
https://virtualcustoms.net/showthread...-for-Windows-7
InformationVery Important!!!
UxStyle Core
There are currently 4 users browsing this thread. (0 members and 4 guests)
Winstep Xtreme ZeroG theme
By gor17981 in forum Nexus DockReplies: 21Last Post: July 27th, 2020, 04:57 PM -
Nameless Red Winstep Xtreme theme
By gor17981 in forum Nexus DockReplies: 7Last Post: September 1st, 2019, 01:01 AM -
Xtreme Blue For Windows 7 x64 and x86
By Psych0t1c in forum psych0t1c's Windows 7 ThemesReplies: 25Last Post: November 1st, 2013, 04:43 AM
Wicked been looking for something as nice as this thanks man
RISEN Theme pack for...
