Results 19 to 21 of 21
December 17th, 2009 11:25 PM #1
Guide to Changing your Start Orb/Button
WARNINGALWAYS CREATE A SYSTEM RESTORE POINT WHEN MODIFYING SYSTEM FILES
Step 1.
Download the Take Ownership context menu shortcut then unzip it and right on the reg file and select merge.
Step 2.
Navigate to c:\ and Take Ownership of the Windows Folder.
Step 3.
Download and install Restorator 2007
Step 4.
Now run Restorator 2007 and open explorer in c:\Windows
Step 5.
Have your new Start Orb/Button ready on the desktop ready to use.
Step 6.
In the left pane in Restorator you will see a folder called Bitmap, expand that folder and you will see a bunch of numbers and each of those numbers represents a Start orb that if clicked on will show you a preview in the Right pane, the main images you need to worry about are 6801, 6805 and 6809.
NOTEIf you are using a larger dpi then the Default Windows dpi then you will have to change the larger start orbs to match your dpi.
Step 7.
Now simply left click and hold on the new Start Orb/Button on your Desktop and drag it onto the relevant numbers in the left pane in Restorator and they will automatically be replaced with your new Start Orb/button.
Step 8.
Right Click on your taskbar and select Start Task Manager and in the processes tab select explorer and then select end process.
Step 9.
Now back in Restorator hit the save button and it will save your new Start Orb/Button and it will create a backup of explorer.exe called explorer backup.exe which you can restore back to default latter if you need to.
Step 10.
Go back to Task Manager and in the menu select New Task (Run...) and type c:\windows\explorer.exe and hit enter, then close Task Manager and Restorator and your done.
Start button / orb
By tistou77 in forum General Windows 10 CustomizationReplies: 0Last Post: October 25th, 2017, 11:06 PM -
Need beginner guide for changing taskbar color
By jeremynpross in forum General Windows 7 CustomizationReplies: 5Last Post: July 7th, 2016, 07:20 PM -
where's start button?
By Leonardo22Tiago in forum General Windows 7 CustomizationReplies: 1Last Post: November 20th, 2013, 09:08 AM -
[help]about changing location button and image location in start menu
By renziye in forum Windows Style Builder v1.5 TutorialsReplies: 2Last Post: August 15th, 2012, 03:20 PM -
Explorer Button Color Changing App
By Psych0t1c in forum DesktopReplies: 4Last Post: January 31st, 2010, 03:12 PM
