Page 1 of 6 12345 ... LastLast
Results 1 to 8 of 47
Thread: How to Apply Custom Themes in Windows 7 Share
    Mr GRiM is offline
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,511
    501 Thread(s)
    For a video tutorial on how to do this please visit this thread: [Only registered and activated users can see links. ]
    This will show you how to apply a custom theme from deviantART as your theme in Windows 7.
    Here's How:
    1. First you will need to click on the Download button below to download and install either the 32-bit (x86) or 64-bit (x64) patcher (auto installer) for your 32-bit or 64-bit Windows 7.
    2. When downloaded, unrar the file using WinRar or similar, and run the exe.
    3. Select your user interface language
    4. Click OK
    5. Then click yes when this box appear.
    6. Then you need to patch these 3 files (As you see i already have mine patched) Click the patch outside each file, after patching them all reboot.
    7. Now you need a custom theme, there's a lot of those here on the site so just find one you like [Only registered and activated users can see links. ]
    You can also find more themes on Deviantart, but make sure they work with windows 7.
    They need to be unzipped first.
    8. Now navigate to the Windows folder, find the folder called resources and click on the themes folder. (C:\Windows\Resources\Themes)
    These are the files that has to be placed in the folder:
    9. Then paste the folder and theme provided, then the theme should appear in your personalization menu
    Note: The files are not named the same in all themes. It’s different from theme to theme. What you need to place in the resources folder is a .theme file and the folder with the same name (the folder is where the msstyles is in)
    Also, in most themes there are only 2 files (a folder and a theme file), but in some cases there can be more. The process is the same though, you will just have more variants of the theme available via the personalization menu.
    Good luck [Only registered and activated users can see links. ]
    Cashis
    Guest
    Re: How to apply custom themes in Windows 7
    Nice job mate.
    Twisted-Devil is offline
    Sep 2009
    36
    182
    1 Thread(s)
    Nice turtorial m8
    rottweilerjocke is offline
    Feb 2010
    25
    Ok thx for all helpfull tip.. but the problem for is.. the toolbar below dosen´t change its the same boring window 7 or vista,,
    Starbuckpga is offline
    Feb 2010
    1
    ***Careful with Windows 7 Enterprise***
    I download the patch utility. Patched all three files, rebooted, then on the login screen it says please wait, so I do, then about 20 seconds later screen goes black, then comes back and it will do this over and over again. The blue default login screen for Windows 7 is visible for 5 seconds, then screen goes black for 2 seconds, and a repeat cycle. Could not get logged into Windows to undo changes.
    Luckily I had a restore point and restored my system back using Ghost 15. So I tried again to see if that was the actual issue causing it, sure enough same thing happened again. So if you have Windows 7 Enterprise installed, this will crash the system and does not work.
    Any alternatives to try by chance? Thanks.
    Mr GRiM is offline
    Bringer of Death
    36
    4,511
    501 Thread(s)
    Quote Originally Posted by Starbuckpga View Post
    You could try VistaGlazz but I don't know how much luck you will have with that because I think it changes the same system files, or there is another method to custom themes that doesn't involve changing any system files.
    VistaGlazz [dl:3lrdrd13]http://www.codegazer.com/vistaglazz/[/dl:3lrdrd13]
  7. #7
    venom30 is offline
    Mar 2010
    1
    Quote Originally Posted by Mr GRiM
    http://www.sevenforums.com/tutorials/34579-enabling-custom-themes-windows-7-a.html
    I got the same problem llike Starbuckpga(i got Win7 Ultimate though). So i tried Mr GRiM's Link, but i didn't help either. When somebody knows something else, tell me please.
  8. #8
    skofild is offline
    Mar 2010
    18
    1 Thread(s)
    CAN YOU HELP ME.....HOW TO UNINSTALL THE THEME IN WINDOWS 7 PLEASE
  1. How to patch windows 7 to allow 3rd party themes and apply themes video tutorial
    By razorsedge in forum Theme & Extras Setup Tutorials
    Last Post: 04-20-2014, 01:11 PM
  2. Custom Themes for Windows 8
    By gooch mango in forum General Discussion
    Last Post: 05-14-2012, 03:15 AM
  3. Certain Windows 7 Themes won't apply properly.
    By TheTorpedo in forum Theme Issues
    Last Post: 04-16-2012, 12:33 PM
  4. Enabling Custom Themes - Windows 7
    By Mr GRiM in forum Theme & Extras Setup Tutorials
    Last Post: 03-08-2010, 03:00 PM
