on the start button you do not have to change that many places there is only 3 places you have to change that is 1,5,and 9 and for the icons you can always go into properties and change them back manually it had to be something in that theme you are using
oh on that start button do you have a pic you can put up so we can see if it might be in the way it looks causing the off center of it
