Results 1 to 4 of 4
Thread: [Tool]Windows Se7en File Replacer v1.5.4 Share
    Fixit is offline
    Mar 2010
    60
    1 Thread(s)
    System modders need to back up and take ownership of a system file before it can be replaced.
    To make this process a little less time consuming I wrote a small program that does these tasks for you.
    This program will:
    1. Backup the OLD file
    2. Save the file ownerships
    3. Take Admin Ownerships
    4. Replace the file with the NEW dragged or manually selected system file
    5. Restore the ownerships back to how they were found
    It does all this in just a few seconds!
    Normally when a file is replaced the file's ownerships are changed and the "TrustedInstallers" will be gone.
    However, the Se7en File Replacer will save all file permissions of the file before replacing it
    and after replacement restores them back to how the Replacer found them!!
    (even TrustedInstallers if the file had them before saving)
    The Replacer will first look in the "system32" folder for a match with your NEW dragged file,
    if the OLD file is found it will be backed up and replaced without prompt,
    otherwise you will be asked to select it manually.
    (note for x64 users: please don't drag SysWOW64 files..
    as they will be placed in the system32 folder, use the manual function instead)
    The manual button will let the user select a new file first and then select the old file which needs to be replaced.
    With this function any file in any location can be replaced.
    It's just an .exe and nothing will be installed.
    WARNING: Use is at your own risk!
    This tool is to replace un-owned system files.
    Be careful not to use this if you don't know what you are doing.
    This can and will break the system if corrupted system files are used to be replaced!
    File extension filter: ".dll" ".exe", in the manual option.
    Will only show these types in the select file dialog.
    Se7en File Replacer
    Version: 1.5.4
    Requirements:
    ~ Windows Vista\Se7en (32bit\64bit)
    Screenshot:
    Full Change log: [Only registered and activated users can see links. ][/center:3dyy01pg]
    I've also added some extra option like:
    "clear icon cache" to refresh your icons
    and a "sfc /scanfile" option to select and restore a single file via the Windows File Protection service in an easy way.
    Hope this will be helpful.
    Notes:
    ~ Replacer will run in Admin mode
    ~ Just an .exe nothing will be installed. At replace of a file a backup "*.*.bak" will be made in its original folder (Once only).
    ~ Drag and drop only works if "UAC" is disabled (you can still use the program by clicking on the "Manual" button.)
    ~ Program written by: Me
    ipazzgazz is offline
    So-Cal
    57
    1
    Re: [Tool]Windows Se7en File Replacer v1.5.4
    will it work ok for changing the login screen? or is there better program for that... I just had to reinstall, and i can't recall how i changed it last time. It seems it was just a matter renaming a file or 2 tho.
    quaz1957 is offline
    Banned
    Sep 2009
    98
    1 Thread(s)
    fixit - excellent - your program will save many lives - really great effort - your the man !!
    Fixit is offline
    Mar 2010
    60
    1 Thread(s)
    @ ipazzgazz: technically it is possible, but something like [Only registered and activated users can see links. ] is more specific for logon changing
    @ quaz1957: wow, Thanx a lot. appreciate it!
  1. Replies: 91
    Last Post: 04-20-2014, 09:35 PM
  2. System File Replacer
    By razorsedge in forum File replacers
    Last Post: 12-26-2011, 09:12 AM
  3. Windows Se7en File Replacer 1.5.4 silent installer
    Last Post: 08-16-2011, 08:25 AM
  4. Easy File Replacer
    Last Post: 12-11-2010, 12:16 AM
  5. BlackViper.com: Windows 7 Custom Services Registry File Tool
    By razorsedge in forum Setup Tutorials
    Last Post: 08-05-2010, 07:20 AM
