Results 1 to 4 of 4
Thread: Explorer frame Share
    darkcold
    Guest
    Explorer frame
    Can someone explain to me how to take the small tweaks for themes found in an explorer frame folder and apply them to the actual theme? Im not great at this kind of stuff so the simpler the terms the better. Thanks
    Mr GRiM is offline
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,511
    501 Thread(s)
    Re: Explorer frame
    1. First you need to get a resource editor like Restorator or Reshacker. (This guide is mainly for Restorator)
    2. Open the C:\Windows\System32 folder and copy the explorerframe.dll and paste it on the desktop.
    3. Open Restorator and drag the explorerframe.dll from the desktop to the left pane in Restorator.
    4. Expand the Bitmaps folder in the left pane.
    5. Open the folder containing the image replacements for your theme.
    6. The images should be Bitmap images named the same as the ones in the Bitmap folder, which are images:
    280, 281, 288, 291, 294, 577, 578, 579 and 581 for the main ones.
    7. Drag each image into the Bitmap folder icon in Restorator in the Left pane.
    8. Save the file on Restortor.
    9. Open the C:\Windows\System32 folder and find the original explorerframe.dll and take ownership of the file and then Rename it to explorerframe.dll.bak.
    10. Copy the explorerframe.dll from the desktop and paste it in the System32 folder.
    11. Restart your computer to take effect.
    [note2:2cjau09w]If your using x64 OS you will need to repeat the same steps for the explorerframe.dll in C:\Windows\SysWOW64[/note2:2cjau09w]
    darkcold
    Guest
    Re: Explorer frame
    thanks for the guide mr. grim
    2fast is offline
    Aug 2013
    Bracknell
    1
    1 Thread(s)
    Hello. I have problems with explorerframe too I did everything you described here, but my start/back buttons and all the other files didn't change even after pc restart :/
  1. Picture Frame Logon and User Frame
    By IcicleThief69 in forum Log On Screens
    Last Post: 08-27-2013, 06:24 PM
  2. Explorer Frame Issues - Image Sizing
    By The Cat with Two Heads in forum Windows Style Builder v1.5 Tutorials
    Last Post: 04-28-2013, 11:12 PM
  3. Replies: 10
    Last Post: 08-15-2012, 01:11 PM
  4. Explorer frame
    By meow1 in forum Windows and caption buttons
    Last Post: 01-01-2011, 03:36 PM
  5. Explorer frame-top-new question*
    By Minotar in forum Windows and caption buttons
    Last Post: 12-31-2010, 05:46 PM
