Page 2 of 2 FirstFirst 12
Results 9 to 10 of 10
Thread: windows 7 start animation Share
  1. #9
    pillou13 is offline
    Jan 2010
    6
    Re: windows 7 start animation
    Created using Adobe after effects. used 35 mm camera.Null objects.In 32 Bits per channel and motion blur enabled. All are 3D layers.Most wanted font from [Only registered and activated users can see links. ]
    this is created for youtube, the one which to be used is a bitmap of size 200X21000, here is the procedure to replace it. Microsoft doesn't recommend it. But i'll do what is not recommended \m/
    For anyone looking for a solution :
    - First, Use ResHack with %windir%\system32\bootres.dll file
    - Extract the RCData resource.
    - So you have two files, one *.rc and another one *.bin
    - Rename the file *.bin into *.wim (not win!!)
    - Use 7zip to extract your *.wim file
    - In the extracted files you have an xml
    which describe the second file which is the boot logon bitmap animation!!!
    Now you can modify the logon animation! But be carefull, to have a correct xml description file!!!
    After modifications, do the inverse procedure, with a backup of your original bootres.dll file.
    I advise you to try on a virtual machine
    before!
  2. #10
    osman_2626 is offline
    Feb 2010
    116
    Quote Originally Posted by pillou13
    before!
    When programming always fails to open
  1. Enable Hidden Start Screen Animation In Windows 8
    By razorsedge in forum Tips and Tricks
    Last Post: 12-08-2012, 03:23 AM
  2. Replies: 0
    Last Post: 12-07-2012, 01:49 AM
  3. Bring back the Windows Start menu with Start 8
    By creator in forum Chill Out Room
    Last Post: 10-06-2012, 01:42 PM
  4. How To Remove Animation & Get Only Text In Windows 7 Boot Sc
    By razorsedge in forum Setup Tutorials
    Last Post: 11-06-2010, 02:14 AM
  5. change copy & move animation colors in windows 7
    By razorsedge in forum Theme & Extras Setup Tutorials
    Last Post: 07-29-2010, 12:50 AM
