Page 1 of 12 1234511 ... LastLast
Results 1 to 8 of 93
Thread: [Tool] Se7en Theme Source patcher v0.3 Build 3003 Share
    Fixit is offline
    Mar 2010
    60
    1 Thread(s)
    Clean [Tool] Se7en Theme Source patcher v0.3 Build 3003
    Hi,
    We're currently working on a Theme Source Patcher for Windows 7.
    sorry, project as good as dead...
    Icon Packs:
    The Icon Packs are still basic and in development.
    However, anyone can build and share there own custom packs.
    containing:
    ~ A custom Logon screen
    ~ A custom side panel bitmap
    ~ A .themepack file or a .theme file and folder
    ~ Custom .ani Cursors
    ~ Customs sounds and sound schemes
    ~ New Fonts
    ~ Any amount of .Res files
    (any system32 file can be added in .res format. e.g. "shell32.dll.res")
    These packs can be installed and used via the options menu in the patcher.
    Pack.ini:
    Code:
    [Base Pack]
    Pack=name of your custom pack
    Base by=name of pack creator
    Version=version number of your custom pack
    Date=date
    [7tsp]
    theme creator=name
    theme=mytheme.theme    <<The name of the theme file as placed in the "Extra" folder, e.g.:  mytheme.themepack or  mytheme.theme (and place the folder that goes with it "mytheme" also in the "Extra" Folder).
    uxhex=yes   <<<In case the theme needs uxtheme.dll to be patched else write "no".
    [taskmanager]
    grid=556677      <<<< only 6 digits correct hex values can be put here.
    CPU=FF0000
    Digits=FF0000
    memory=FF6A00
    [CopyAnimation]
    color1=000000
    color2=000035
    color3=003C77
    Fontcolor=FFFFFF
    Se7en Theme Source Patcher
    The Se7en Theme Source Patcher has been built from scratch, including the new res files and modifications made by Kirs.
    More then 85 files and 426 icons, bitmaps and cursors can be replaced with one of the official basic color packs,
    and any amount of res files can be used in a personal pack as long as the system file exists.
    The Patcher:
    Download: 7tsp_GUI_v0.3_B(3003)
    Full change log: [Only registered and activated users can see links. ]
    Options:
    Start Patching: Patch your Windows 7.
    You can select a custom pack in the Options menu.
    It is also possible to merge your custom pack with the internal Black pack.
    Restore: Restores the patched files to the backup made at 7tsp's first run.
    For extra security, the patcher by default creates a Restore Point every time you patch your system.
    You can disable this in the Options menu.
    It is also possible to manually create a Restore Point (Program > Create Restore Point).
    Logon Screen:
    You can select whether the Logon screen should be patched or not, and you can also select a custom picture.
    Side Panel:
    You can select weather the Side Panel should be patched or not, and you can also select a custom picture.
    Cursors:
    You can select whether or not the animated cursor files should be replaced.
    Explorer.exe:
    You can select whether or not Explorer.exe should be patched.
    Debug log:
    Here you can select whether or not a debug log should be created. This is useful for pack creators, to debug resfiles.
    Clean Icon Cache:
    When not all icons have changed, you can manually clean the icon and thumbnail cache to refresh these.
    What happens to your system files:
    1. If Start Patching is clicked, the Patcher will extract the selected resource pack to the work folder and look for each system file this pack will mod.
    A backup will be made of those files in the case a backup does not yet exist. If Windows updated a file the backup will be updated as well.
    2. The current file ownerships of a file are stored and then administrator ownerships are taken.
    3. The file will be patched with the new resources and replaces the original file.
    4. The file ownerships will be restored.
    To Do:
    ~ add task manager color change support
    ~ add more detailed start button support
    ~ Add GUI language support
    Notes:
    Windows 7 Only! (x86/x64)
    Icons were modified using: Icon FX
    Bitmaps were modified in: Paint.net and gimp
    More options and icons will be added along the way..
    Regards,
    Fixit
    Mr GRiM is online now
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,546
    525 Thread(s)
    Re: [Tool] Se7en Theme Source patcher
    Nice work Fixit and though the icons are basic they are still very appealing, feel free to use any of my packs to create installers with also
    Dave Senior is offline
    Mar 2010
    397
    26 Thread(s)
    This looks fascinating, I,ll have to read it a few times to get my head round it.
    Amazing, this will help loads of people,adding the extras that come with themes sometimes causes problems for people.
    great job!
    Fixit is offline
    Mar 2010
    60
    1 Thread(s)
    Thanx a lot!
    if u need any help just ask
    Larsen is offline
    May 2010
    Denmark
    33
    19
    2 Thread(s)
    what windows 7 version is it for? x64 or x86 or both?
    Fixit is offline
    Mar 2010
    60
    1 Thread(s)
    it is for both x86 and x64.
  7. #7
    tytynono is offline
    Oct 2009
    7
    3 Thread(s)
    Quote Originally Posted by Fixit
    Hello, I would like make a french version of your Se7en Theme Source patcher but i can't nor with reshacker or hex editor, is it possible to make a language file?or any way.Thanks for french user.
  8. #8
    Fixit is offline
    Mar 2010
    60
    1 Thread(s)
    i have put it on the todo list..
    ill write a translation code, to use a lang.ini to translate the program it self...
    but as this needs some major rewriting of all text areas in the script this could take a while..
  1. Universal Theme Patcher 1.5 silent installer x86 & x64
    By razorsedge in forum Theme Patchers
    Last Post: 06-14-2014, 11:18 PM
  2. Windows 8 theme patcher problem?
    By Ryan_Se7en in forum General Customization
    Last Post: 08-05-2013, 08:53 AM
  3. Universal Theme Patcher - Manual Install
    By Big V in forum Theme Patchers
    Last Post: 09-24-2012, 04:21 PM
  4. Extreme Spider-Man 3 Theme Windows Se7en
    By Venom0642 in forum Venom0642's Windows 7 Themes
    Last Post: 04-04-2012, 11:41 PM
  5. [Tool]Windows Se7en File Replacer v1.5.4
    By Fixit in forum Fixit Tools
    Last Post: 11-05-2010, 10:39 AM
