Results 1 to 3 of 3
Thread: Converting PNG to BMP Files Share
    greg0323 is offline
    Apr 2010
    28
    I'm seeming to be having an issue converting Png files i've DL'ed for the User Frames and the Clock, I'm using Paint Shop Pro X2 to convert them to bmp, then I use restorator 2007 to modify explorer.exe and other files. Either I see no change in the file like time.cpl file or the frame disappears from around my user photo on the start menu. Is there something I'm not doing? I'm able to put in other bmp files I've downloaded from here.
    *** Sorry I posted this in wrong forum. Its intended for General Customization section.
    Mr GRiM is offline
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,546
    526 Thread(s)
    Re: Converting PNG to BMP Files
    First of all are you using x64 Windows and if so are you replacing the timedate.cpl in SysWOW64 as well?
    With the userframe did you make sure it was the right size and did you save it as a 32bit Bitmap, it should tell you in the properties if you did.
    greg0323 is offline
    Apr 2010
    28
    Yes sorry, I'm using Windows 7 64 bit. I have not tried it in the wow64 folder on that file, everytime I open it after change system32 file first It looked like it switched it in the wow64 folder. I will retry this.
    My userframe is being saved as 32 bit in the properties. its 64x64.... I'm using the green user frame png file that you posted with all the others, I'm also in need of a larger one for the Logon screen if you could.
    Quote Originally Posted by Mr GRiM
  1. Converting a .cdr to .ai or .eps
    By lwarmachinel in forum Files and Folders
    Last Post: 07-08-2012, 10:11 PM
  2. SOE Converting Another MMO to F2P: Vanguard
    Last Post: 03-26-2012, 09:16 AM
  3. X-FILES
    By razorsedge in forum AIMP2
    Last Post: 10-18-2010, 07:42 AM
  4. That many files?!?!?!
    By SilentShadow in forum Theme Building Questions
    Last Post: 09-29-2010, 01:07 PM
  5. Converting WIN xp Style to WIN 7
    By blackdespair in forum Theme Requests
    Last Post: 09-22-2010, 04:40 PM
