Page 1 of 2 12 LastLast
Results 1 to 8 of 9
Thread: Weird windows 7 error. Share
    Detective RooTz is offline
    Jul 2010
    11
    I have a weird error on my machine.
    I try to access teamviewer 5, some pictures or a downloaded movie and I get his occasionally. It most occurs with pictures.
    I do not know what the exact problem is other than it says I have no permissions to view them when I have not touch anything about permissions and I even give my self permission via the .dll file I have and it still says it.
    wassamatteru is offline
    Jun 2010
    96
    Re: Weird windows 7 error.
    Generic error messages are only guesses when it comes to it so don't assume that it's anything to do with permissions necessarily. What manner of device are these files stored on? Does the error persist after a restart? Are you starting the files from shortcuts, from the file manager, run dialog etc. ?
    Jul 2010
    11
    Quote Originally Posted by wassamatteru View Post
    The particular picture I was trying to view is on my C: on my desktop in a folder called "My Stuff"
    So, the picture is local.
    It's suppose to open with Opera or the Windows photo viewer and it never does with either. Occasionally it will open with opera though.
    No the shortcuts because it's the original file I moved to the "My Stuff" folder.
    Jun 2010
    96
    The most likely explanation is that the file is corrupted. Try copying it to another folder and see if there's any problems in the transfer and if it still behaves the same in the new directory.
    If the file is downloaded or transferred from another computer it may be blocked. You can unblock in the right click > properties > General. Also check the Security and Details tabs too to make sure that you actually do have the permissions you think you should.
    Failing all else I'd move "My Stuff" out of Desktop altogether.
    Jul 2010
    11
    Why would you move it?
    IT's where I keep all my program shortcuts and folder of and 4chan stuff and all that.
    I've never had this problem, iot just started recently occuring.
    JoseyWales is offline
    Nov 2009
    Virginia Beach, Virginia, United States
    47
    299
    54 Thread(s)
    if you reinstall win7 but keep older files on the drive permisions will be set to the old os user account and they will need to be "owned" by the new os. you can use take control or another such program to set the file or pic to your new user account. not that it's "new" but anything that was on the drive before install will need to have it's security changed to the new user account.
  7. #7
    Jul 2010
    11
    Quote Originally Posted by JoseyWales View Post
    I know this is a security risk but I've went around and gave my whole C: and D: full control.
    Now, it fixed the image problem.
  8. #8
    Jul 2010
    11
    I still have a problem with iexplorer.exe(Internet Explorer)
    I have checked. I have full permissions except for special and write but still I get the same error.
    I've ran the "Take Ownership" script I got on my whole C: so all my stuff should let me in now.
  1. Weird Box when Driaging a windows!
    By ONE MAN ARMY in forum General Questions
    Last Post: 06-05-2013, 03:59 PM
  2. Troubleshoot Volume Activation error codes and error message
    By razorsedge in forum Competitions, News & Reviews
    Last Post: 03-01-2011, 06:29 AM
  3. Windows 7 SP1 error msg: following updates might need reinst
    Last Post: 02-18-2011, 11:14 AM
  4. Fix: Error 1079 – Windows Time, Windows Event Log, Windows F
    Last Post: 02-01-2011, 02:04 AM
  5. Fix: Error code 0x8007000D when trying to activate Windows 7
    Last Post: 10-11-2010, 09:32 PM
