Results 1 to 4 of 4
Thread: Change this font?? Share
    RBCC is offline
    Mar 2010
    60
    Change this font??
    I know Dave has better things to help with the same problems over and over, I am using his tut while I work on mine but couldn't find how to change the fonts in the words "shut off" and "Search all programs" Where is it? John
    Dave Senior is offline
    Mar 2010
    397
    26 Thread(s)
    Re: Change this font??
    For the search-
    Fonts, Colors & System Metrics > Fonts & System Metrics > ICONTITLEFONT
    For the shut down you can try adding a font property to the location where you change its text color, you have to experiment with these things , see the last post in the guide, I,m not doing your theme, you are, if you want to do new things, you have to put the hours in finding them
    Mar 2010
    397
    26 Thread(s)
    I,ll give you a tip mate, you can try adding the font property at any location where there is an option to change the text color but no font option available, you,re not guaranteed a result but you can try.
    wassamatteru is offline
    Jun 2010
    96
    If all else fails, NoSegoe [Only registered and activated users can see links. ]
    Simply insert your preferred substitute font name into the registry merge file.
  1. How to change GroupHeader font?
    By failure13 in forum Explorer and shell
    Last Post: 02-13-2013, 01:33 PM
  2. change font
    By chopper13 in forum General Questions
    Last Post: 08-03-2011, 10:59 PM
  3. How to change these font colors
    By voodoomonkey in forum Theme Building Questions
    Last Post: 06-09-2011, 06:26 PM
  4. how to change clock font?
    By peinz in forum Theme Building Questions
    Last Post: 06-04-2011, 06:48 AM
  5. Need Help .. Change this font ..
    By macubex182 in forum Fonts, colors and system metrics
    Last Post: 01-24-2011, 11:41 AM
