Results 7 to 7 of 7
Thread: Customize Windows 7 Media Center with Media Center Studio
    razorsedge is offline
    The Sci-Fighter
    Oct 2009
    5,016
    16 Post(s)
    434 Thread(s)
    Windows 7 Media Center does not include native theme support but that has not stopped a determined group of users armed with resource hackers and custom tools to make customizing Windows Media Center easy.
    To get started I’m going to show you how to use a free utility called Media Center Studio to create and install your own theme. The Media Center Studio will allow you to customize all of the colors, fonts and images used in Windows Media Center.
    First, download and install Media Center Studio.
    Thanks to daspannerman for the installer
    The above link is a stand alone installer since the site is no longer exists.
    if you have any issues where u can change the theme but when you move tiles around or add customs stirps the changes dont take effect.
    use this patch to correct the issue
    thanks to tikuf for the patch
    Place in same location as StartResources.dll usually
    C:\ProgramData\Microsoft\eHome\Packages\MCEClientUX\dSM
    and run it it will backup the original.
    StartResources.dll may be in multiple locations within the C:\ProgramData\Microsoft\eHome\Packages\MCEClientUX\ directory
    After the software is installed and running click the green New button on the ribbon.
    Attachment 34703
    Now you will see all of the items that can be customized. It is best to set the name and author sections first.
    Attachment 34704
    Navigate through the sections on the left to customize each component. Most users like to change the background image so I’m going to cover that first. Navigate through Images, Common and Backgrounds. There are two items under Backgrounds that you will need to replace to change the Windows Media Center background.
    Select COMMON.ANIMATED.BACKGROUND.PNG and click Browse.
    Attachment 34705
    Browse and select the new background file and then click the Open button. You may need to change the file type drop down box to JPG if your replacement picture is not a PNG file.
    You should now see your new image shown. Now select the next item, COMMON.BACKGROUND.PNG, and repeat as you did for the last item.
    After both items are replaced with your new image you are ready to finalize your theme. First, save your progress by clicking Save.
    Attachment 34706
    Navigate back to the Biography section list on the top of the navigation list. One of the last steps is to create a thumbnail shot for your new theme.
    On the Biography screen click the play camera button.
    Attachment 34707
    Windows Media Center will load with all your settings loaded. While Media Center is still running, switch back to Media Center Studio and click the new picture camera button.
    Attachment 34708]
    Click the stop camera button and the preview image will be saved and Media Center closed.
    Attachment 34709
    Now that the picture was saved, while selected, click the up arrow to set the preview picture as the default thumbnail for your theme.
    Attachment 34710
    Then hit the Save button once more and your theme is completed.
    To apply switch over to both Themes tabs and select your theme and hit Apply.
    Attachment 34711
    Since the site for this
  1. Get Windows 8 Media Center Pack for free till january 31st
    By razorsedge in forum Help and Support
    Last Post: December 7th, 2012, 02:30 AM
  2. XBMC Media Center!
    By ~TripleAceS~ in forum Media Players
    Last Post: August 6th, 2012, 01:12 PM
  3. Windows 7 Media Center Modded by ~ArtisticMan10
    By razorsedge in forum Media Center
    Last Post: August 8th, 2010, 12:14 PM
  4. Windows Media Center Gadget
    By armani077 in forum Desktop Gadgets
    Last Post: July 10th, 2010, 01:31 PM
  5. Windows 7 Media Center Customization Handbook
    By Cashis in forum Media Center
    Last Post: May 1st, 2010, 08:36 PM
