Page 3 of 4 FirstFirst 1234 LastLast
Results 17 to 24 of 29
Thread: Updated Class Map for WSB 1.5 Share
    Mr GRiM is online now
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,546
    526 Thread(s)
    Clean Updated Class Map for WSB 1.5
    NEW!! - Update 21/08/2010
    Some of you seem to be having a bit of a problem and are freaking out about locations not being there, so I will give you the list of changes to clear things up a bit
    Changes:
    1. Fixed Tool Window Left and Right Frames.
    2. Added extra states to the Tabs so they are all the same.
    3. Renamed Toolbar Split buttons Appropriately and added extra states for the Drop Down Glyph.
    4. Header Consistency added, all buttons have all their States now the same as HeaderItemRight.
    5. Items View Header Consistency added, all buttons have all their States now the same as HeaderItemRight.
    6. Tabs now have full states for all Buttons the same as the top.
    7. Preview Pane has been renamed to Details Pane and the properties have been named.
    8. Reading Pane had been renamed to Preview Pane and properties have been named.
    9. Proper Tree has been renamed Navigation Pane and properties have been named.
    10. Command Module has been renamed to Toolbar and Library Pane and all properties have been named.
    11. MonthCal has all properties named.
    12. To be continued.....
    In explorer I also rearranged the panes so they are in the same order you would see them in the layout options in explorer
    Download
  2. #17
    Bringer of Death
    36
    4,546
    526 Thread(s)
    Re: Updated Class Map for WSB 1.5
    Quote Originally Posted by Big V View Post
    how do i appy the update
    just make a backup of your old ones and put them here C:\Program Files (x86)\AveApps\Windows Style Builder\Data\Win7
  3. #18
    Pitbull_NL is offline
    Aug 2010
    3
    thanks for your work on this
  4. #19
    megabink is offline
    Jan 2010
    43
    2
    1 Post(s)
    1 Thread(s)
    Fantastic mate,this is cool thanks for this one.
  5. #20
    Fatezoom is offline
    Aug 2010
    17
    72
    This is amazing man!!!
  6. #21
    vagojuan is offline
    Palmira, Colombia
    46
    17
    exelente , justo lo que me faltaba , gracias
  7. #22
    shaka_de_virgo is offline
    Mar 2010
    the sanctuary Greece
    26
    2
    gracias mr grim, gracias a tu update creo que ya podré seguir los tutoriales que e visto en virtual customs: como el tutorial para poder modificar un tema completa mente, yo ya tenia un tema avanzado pero si no avanzaba era por que yo para modificarlo era, a base de prueba y error, pero con tu actualización y el tutorial que ahora me imagino ya todas las ubicaciones serán correctas como en el Tuto creo que seré capas de completar mi creación.
    gracias mr. grim.
    de paso te informo que use tu actualización en una versión no oficial con algunas traducciones de texto en español con esto me refiero a que solo fueron las opciones y algunas cosas que se tradujeron ya que las ubicaciones y propiedades y demás quedaron en ingles, y a pesar de que es retocada y cambian ciertos nombres de ruta al final lo importante es que tu actualización funciono también en mi versión en mi caso la ruta para poner la actualización fue C:\Program Files (x86)\hacker2009i\Windows 7 Style Builder\Data\Win7
    thanks mr grim, thanks to your update and I think I can follow tutorials and virtual customs seen: as the tutorial to modify a theme complete mind, I already had an advanced topic, but if no progress was because I was to modify , through trial and error, but with your tutorial update and now I guess since all locations are correct and in the layers Tuto think I'll be completing my creation.
    thanks mr. grim.
    the way you use your update reported that an unofficial version with some text translations in Spanish that I mean they were only options and some things that were translated as the locations and properties and others were in English, despite that is tweaked and changed some path names to the bottom line is that your upgrade worked well in my version in my case to put the upgrade path was C: \ Program Files (x86) \ hacker2009i \ Windows 7 Style Builder \ Data \ Win7
  8. #23
    lahercoll is offline
    The Golden Dragon
    Nov 2009
    japan
    1,337
    8 Post(s)
    257 Thread(s)
    thank you master thank you I already understood Mr. griem thousand thank you.
  9. #24
    Allusion is offline
    Mar 2012
    Smyrna
    7
    sorry to do a bump to an old thread, but i was wondering have these changes been done to the program when you buy it from the original vendor, i finally bought the program today and was wondering if i would need to put in this file or if i should leave it alone
  1. M-CLASS MINIMAL
    By bigcyco1 in forum Rocketdock
    Last Post: 10-18-2012, 02:30 AM
  2. M-Class Walls
    By Oshea in forum Wallpapers by Other Great Artists
    Last Post: 06-21-2012, 10:16 AM
  3. A class
    By cybacreep in forum Wallpapers Posted by cybacreep
    Last Post: 03-21-2012, 01:39 PM
  4. M-CLASS v2
    By Dalon in forum Rocketdock
    Last Post: 12-28-2011, 11:13 AM
