Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 17 to 24 of 73
Thread: Annihilator For Windows 7 Share
    Mr GRiM is online now
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,546
    526 Thread(s)
    Alert Annihilator For Windows 7
    Youtube Video made by HaCkthEplAneT
    Prepare to be Annihilated with my latest theme, this project was started with some ideas that razorsedge and I had for a theme that we worked on together to begin with and then we both had some of our own ideas and we decided to have a small competition to see who's ideas would turn out the best.
    We made a thread about it which was allot of fun, which you can find here called [Only registered and activated users can see links. ] and you can see some of the ideas we both had, from that I came up with 2 design concepts, a light and a dark theme and razorsedge continued with the theme now known as Supernova that has now been released and he has done a really excellent job on it, you can get his new theme here [Only registered and activated users can see links. ].
    So this is the first of 2 themes, my light version is still only a concept and I haven't started making it into a theme yet but it will happen and will be released in the near future, both themes will be packed for use with 7tsp and can be installed or uninstalled using 7tsp found [Only registered and activated users can see links. ]
    Theme Includes:
    Annihilator Theme
    Full Glass Blue Icons
    System Clock
    Shell32 Control panel images
    MAX Glass Icons by basj
    New Sound Schemes, Tinker, Glass & Pearl
    ieframe (IE8) Skin/Mod
    System Properties Logo
    Getting Started top Pane
    Games Menu Preview Pane
    New Fonts Eurostile & Micrograma
    Other stuff I forgot to mention
    All features you see above will be installed automatically using the 7tsp installer, if there are features you do not want installed then you may have to remove them from the pack before installation, a restore point will be made before install and there is also an uninstall option in 7tsp.
    Download the Annihilator theme Extras [Only registered and activated users can see links. ]
    Download the theme here [Only registered and activated users can see links. ]
    Or if you want just the theme Download this one. [Only registered and activated users can see links. ]
    Update: 13-10-2010 - Fixed a bug with explorer crashing when changing taskbar position and tooltip problem being too close to mouse pointer, theme also updated optimized for full use with Theme Resource0 changer, please use 7tsp to uninstall old theme first and make sure it has been removed from the personalization menu before using the updated theme.
  2. #17
    Big V is offline
    A Supreme God
    Feb 2010
    Cornfeilds of Indiana
    2,764
    21 Post(s)
    296 Thread(s)
    Re: Annihilator For Windows 7
    yes it was checked fixit
  3. #18
    ZeroKnight is offline
    Aug 2010
    20
    15
    Very nice! You really are the best Win7 stylist GRiM.
    The theme is beautiful, though I have one gripe. I know it's for effect, but I'm not partial to there not being anything for maximize/restore and minimize. Since the buttons are different sizes, it's a bit too much guesswork.
    Other than that I find no other fault with it. Excellent work GRiM.
  4. #19
    Bringer of Death
    36
    4,546
    526 Thread(s)
    Quote Originally Posted by Fixit
    Hi,
    Cursors install via inf will be available in the next update of 7tsp...
    for the logonui background, did u select the check box to patch it?
    thanx for reporting.
    Fixit that will hapen because he has used another program already to change his log on screen and they will override the ones from the theme as they are in C:\Windows\System32\oobe\Info\backgrounds and they will overide the default ones if you have ones in there, maybe we it would be best if the log on images went in there instead of the imageres.dll.
    Also there is a checkbox in the cursors selection screen to change the cursors with the theme so he may have unchecked that already, when I tested the installer on the VM it was a fresh install and everything was installed fine, the only problem I did have though was the fonts didn't get installed.
  5. #20
    Bringer of Death
    36
    4,546
    526 Thread(s)
    Quote Originally Posted by ZeroKnight
    Not that I think anyone should have a problem knowing what the 2 buttons are for but anyway here is one for you with some different coloured ones, I hope that will be better for you.
  6. #21
    Fixit is offline
    Mar 2010
    60
    1 Thread(s)
    for the logonui,
    that would not be to hard. ill see what i can do with it...
    cursor install via inf is already supported, but the inf needs to be called "cursors.inf"
    and i'll take a look at the fonts...
    thanx Mark
  7. #22
    Aug 2010
    20
    15
    I like the way that looks, thank you GRiM ^__^
  8. #23
    Dalon is online now
    Feb 2010
    47
    153 Thread(s)
    hi, Mark
    your annihilator theme is a perfect example of your génial creativity. Perfect and serious job, thanks for your hard job.I' am KO and OK....
    THANKS YOU VERY MUCH....
    The imagination is more important than the knowledge.
    Citations de Albert Einstein
  9. #24
    sounddevil13 is offline
    Mar 2010
    foley, mn, us
    33
    197
    23 Thread(s)
    Best theme Ever!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  1. Annihilator For Windows 7
    Last Post: 04-19-2014, 06:42 AM
  2. Annihilator Icon
    By Sarcastic in forum Custom Icons
    Last Post: 01-02-2011, 12:37 PM
  3. Installing Annihilator Light
    By julio99 in forum Theme Issues
    Last Post: 10-01-2010, 01:53 AM
