August 25th, 2010 07:22 PM #1
Windows 7 Start Orb Loader 1.1 by ~stkov
Attachment 36153
System Requirements
Windows 7 x86 or Windows 7 x64
with default shell (i.e. Windows Explorer.)
Note: not tested on Windows Server 2008 R2.
Features
1. Change your start orb WITHOUT changing explorer.exe.
2. Choose different start orb for each user.
3. DPI-aware.
Install/Uninstall Guide
Uninstall of version 1.0: run the loader (renamed to explorer.exe), press 'Unload' button, and delete it. Current version is not compatible with ver. 1.0, so uninstall old loader before using current release.
Install of version 1.1: run the loader (w7soldr.exe in the zip, and you can rename it as you want), check 'Options' > 'Enable start orb loader' and press 'Save changes' button. Read usage section for details.
Uninstall of version 1.1: run the loader, uncheck 'Options' > 'Enable start orb loader', uncheck 'Options' > 'Shell integration' and press 'Save changes' button. This will restore all changes done to your system. Delete the loader then you're done.
Summary of Usage (Check details in readme.txt!)
1. Extract the zip and run w7soldr.exe.
2. Check 'Options' > 'Enable start orb loader'.
3. Press 'Browse' button to choose the location that contains start orbs you want to use.
4. Choose a start orb you want to use.
5. Press 'Save changes' button to save changes.
* Checking 'Options' > 'Shell integration' appends a menu item labed 'Start orb' on the context menu of desktop background.
Window Metrics Loader for Windows 8/8.1 and Windows 10
By georchin in forum Customization ToolsReplies: 2Last Post: November 5th, 2019, 09:28 PM -
StartW8 - Windows Start Menu replacement for Windows 8 and Windows Server 2012
By razorsedge in forum Customization ToolsReplies: 0Last Post: December 7th, 2012, 01:49 AM -
Bring back the Windows Start menu with Start 8
By creator in forum Chill Out RoomReplies: 1Last Post: October 6th, 2012, 01:42 PM -
Clean Windows 7 Start Menu with Start Menu Cleaner
By razorsedge in forum System, Junk, Reg CleanersReplies: 0Last Post: July 29th, 2010, 05:03 AM
Post Your Windows 11...
