September 29th, 2010 10:56 PM #1
WARNING: This tool is intended for experienced users. Please do not try it if you are not familiar with such kind of customization stuffs. We'll not be responsible if you break your system with this tool. So use it at your own risk.
Make sure to take a backup of system files before replacing or modifying them so that you can restore them later.
Now the wait is over. Since when Microsoft released Windows 7, no one was able to change the boot screen as it requires lots of files and certificates hacks.
But now Jeff Bush @ "Coder for life" website has developed an excellent tool which can customize Windows 7 boot screen.
"Windows 7 Boot Updater" is a program that makes it easy to update the Windows 7 boot animation and text. It is written in C++/CLI and requires Microsoft .NET Framework 2.0 and the Microsoft WIM library.
[attachment=0:2lp6xhtf]Windows_7_6956_Bootscreen_by_killer7ben.jpg[/attachment:2lp6xhtf]
Features List:
* Modifies the boot animation
* Modifies the boot text "Starting Windows" and "Microsoft Corporation"
* Will compile the animation from 105 BMP, PNG, GIF, or TIFF images
* Does not require any other applications (like ImageX)
* Designed to be idiot-proof by having numerous checks
* Automatically backs up the modified winload.exe and bootres.dll
* Can be run as a GUI or command-line program
* Works for 32-bit or 64-bit Windows 7
* Numerous other little things (e.g. forcing timestamps) to match the original
The software is available for both 32-bit and 64-bit versions.
download and more information can be found here: viewtopic.php?f=92&p=21605#p21605
boot screen windows 10
By Levi Vladimir in forum Windows 10 Theme Help and SupportReplies: 7Last Post: December 12th, 2016, 11:53 PM -
Change the Windows 7 Boot screen with Boot Updater
By HammerJack in forum Windows 7 Theme Help & SupportReplies: 8Last Post: April 12th, 2013, 11:07 PM -
By razorsedge in forum MiscellaneousReplies: 22Last Post: June 27th, 2011, 06:16 AM -
How To Get A Blank Boot Screen In Windows 7
By razorsedge in forum Setup TutorialsReplies: 0Last Post: November 6th, 2010, 02:17 AM -
Make Windows boot faster using Windows Boot Performance Diag
By razorsedge in forum News & ReviewsReplies: 0Last Post: September 6th, 2010, 10:47 PM
