Results 121 to 126 of 127
October 9th, 2010 06:55 AM #1
Theme Resource Changer no more dll editing..
The days of editing dll's to change themes are now gone....
Theme resource changer installed once on your system will do it's magic for any theme you use.
It's very simple just create 3 folders inside your theme folder with all the images you need for your explorer.exe, explorerframe.dll and your shell32.dll and like magic...
When you apply you theme all your resource images are now changed no editing no rebooting switch themes as often as you like after they have been set up with the images and completly transform your computer in a matter of seconds with Theme Resource Changer...
Package includes theme resource changer for x86 and x64 systems, test theme already set up with the folders and images to show you how its done and how simple it is. After the app is applied you can apply the test theme right away to see how easy it works.
Instructions also included enjoy theme resource changer making your themeing life that much easier
Important Update: 22/11/2010 Updated Theme Resource Changer installer to work with all drive letters, it was only reading on C drive previously, also fixed the restart explorer.bat to exit when finished.
Also included the full Tutorial as linked below.
Please not that if you have already installed it and it's working then there is no need to download this update
A tutorial on how to use theme resource changer can be found here: https://virtualcustoms.net/showthread...source-changer
Update: 21/04/2011 Thought I had fixed the problem with the drive letter but in case you are still having any problems getting theme resource changer to work then use this reg fix.
Attachment 41977
theme resource changer.rarLast edited by Mr GRiM; July 7th, 2013 at 04:30 AM.
How to use theme resource changer
By razorsedge in forum Windows 7 Theme Help & SupportReplies: 96Last Post: December 18th, 2020, 01:32 PM -
Need Help with Theme Resource Changer
By edee in forum RequestsReplies: 5Last Post: December 18th, 2011, 07:24 AM -
By razorsedge in forum General Windows 7 CustomizationReplies: 2Last Post: December 31st, 1969, 11:00 PM -
By razorsedge in forum News & ReviewsReplies: 2Last Post: December 31st, 1969, 11:00 PM
