October 20th, 2010 01:03 AM #1
How To Hide Drives In Windows 7 Using Command Prompt
The Command Prompt in Windows is a very powerful tool to accomplish certain tasks that usually can’t be done unless you have a third-party tool. We have already covered a few guides such as how to install Windows 7 via USB flash drive and how to add/delete/rename power plans using Command Prompt.
Attachment 37801
Today, we are going to share another interesting use of Command Line. One can use the Command Prompt to hide one or more drives in the explorer. Of course, you can use a free tool such as DriveHide to do the same. But, if you can remember a few commands, you can easily hide a drive in a few seconds without using a third-party software.
Here is how to do it:
1. Type CMD in Start menu search area and hit Enter to launch Command Prompt. You can also find the Command Prompt under Accessories category in Start menu.
Attachment 37802
Attachment 378042. In the Command Prompt, type Diskpart and hit enter key. Click Yes if you are prompted with UAC (User Account Control) dialog-box.
Attachment 37804
3. And then type List Volume and hit enter to see list of all drives.
Attachment 37805
4. Select the drive that you want to hide. To do this, type Select Volume G (here, G is the drive letter) or Select Volume 8 (here 8 is the volume number)
Attachment 37806
Attachment 37807
5. To hide a drive, type Remove Letter G. Here, G is the drive letter than you want to hide.
Attachment 37808
6. You are done.
To show the hidden drive, follow the steps given below:
1. Follow the procedure mentioned in step 1, 2, and 3.
2. Select the volume number for which you want to assign a drive letter and show in the explorer. Type Select Volume 8 (here, 8 is the volume number) and hit Enter key.
3. Once selected, type Assign Letter G and hit Enter key to see the drive in explorer(replace G with the drive letter that you have previously removed).
Attachment 37809Last edited by Big V; August 12th, 2011 at 05:55 AM.
how to hide back and fort buttons in windows 10 explorer 20H
By Moaz in forum General Windows 10 CustomizationReplies: 5Last Post: November 19th, 2021, 06:51 AM -
How to hide "Command Bar" or "Organize Bar" on Windows 10 Anniversary.
By majestyca in forum Windows 10 Theme Help and SupportReplies: 5Last Post: December 12th, 2016, 02:49 PM -
How To Pin Command Prompt With Admin Rights To Start Screen
By razorsedge in forum Tips and TricksReplies: 0Last Post: December 8th, 2012, 02:33 AM -
How to Auto-Hide or Disable Command Bar (aka Folder Band)
By razorsedge in forum Windows 7 Theme Help & SupportReplies: 3Last Post: June 20th, 2012, 06:32 PM -
How To Change Command Prompt Text And Background Color In 7
By razorsedge in forum General TutorialsReplies: 0Last Post: April 2nd, 2011, 04:19 PM
ROG Tweak Theme for...
