Thread: Windows Memory Diagnostics Tool in Windows 7 Share
    razorsedge is offline
    The Sci-Fighter
    Oct 2009
    40
    4,859
    16 Post(s)
    293 Thread(s)
    Window has a Memory Diagnostic Tool which you can use to check for possible memory problems, including testing of the Random Access Memory (RAM) on your computer.
    If Windows 7 or Vista detects a possible memory problem, you will receive a notification. Click the notification to open it.
    If you wish to run this Windows Memory Diagnostics Tool on demand, open Control Panel and type ‘memory‘ in the search bar. Click on ‘Diagnose computer memory problems’ to open it. Alternatively, you can also type ‘mdsched‘ in start search and hit Enter to open it.
    Choose between two options for when to run the Memory Diagnostics Tool.
    If you choose to restart your computer and run the tool immediately, make sure that you save your work and close all of your running programs. The Memory Diagnostics Tool will run automatically when you restart Windows. It might take several minutes for the tool to finish checking your computer’s memory.
    Once the test is completed, Windows will restart automatically. If the tool detects errors, you should contact your computer manufacturer for information about fixing them, since memory errors usually indicate a problem with the memory chips in your computer or other hardware problem.
    Advanced options for running the Memory Diagnostics Tool:
    For most users, letting the Memory Diagnostics Tool run automatically is the recommended option. However, advanced users might want to adjust the tool’s settings. When the Memory Diagnostics Tool starts, press F1.
    You can adjust the following settings:
    * Test mix. Choose what type of test you want to run: Basic, Standard, or Extended. The choices are described in the tool.
    * Cache. Choose the cache setting you want for each test: Default, On, or Off.
    * Psss count. Type the number of times you want to repeat the test.
    Press F10 to start the test.
  1. Physical memory allocation and memory status in Windows 7
    By razorsedge in forum Competitions, News & Reviews
    Last Post: 03-05-2011, 02:17 AM
  2. System Preparation Tool (Sysprep) in Microsoft Windows 7
    By razorsedge in forum Instalation Tutorials
    Last Post: 03-01-2011, 06:20 AM
  3. [Tool]Windows Se7en File Replacer v1.5.4
    By Fixit in forum Fixit Tools
    Last Post: 11-05-2010, 10:39 AM
  4. P2V Migration Tool for Windows 7 released by Micros
    Last Post: 09-16-2010, 09:32 PM
  5. Greenshot – Freeware screenshot tool for Windows
    By razorsedge in forum Graphics
    Last Post: 07-31-2010, 05:33 AM
