Page 1 of 16 1234511 ... LastLast
Results 1 to 6 of 96
Thread: How to use theme resource changer Share
    razorsedge is offline
    The Sci-Fighter
    Oct 2009
    45
    5,230
    16 Post(s)
    402 Thread(s)
    Theme Resource Changer Instructions
    Theme Resource changer eliminates having to edit dll or exe files to replace the images in your explorer.exe, explorerframe.dll
    and your shell32.dll
    1. To use the Theme resource changer download and run the Theme Resource Changer.exe x86 or x64 depending on what operating system you are using. Theme resource changer can be found here: [Only registered and activated users can see links. ]
    2. After installation it will automatically restart explorer and you are set you only have to apply this just the one time and it will work for any theme that you setup to use it with.
    3. To set your themes to use the Theme Resource Changer all that is needed is to make 3 folders inside your theme folder, with these names
    explorer.exe
    explorerframe.dll
    Shell32.dll
    like in the screen shot below:
    These folders go inside your theme folder you have in windows\resources\themes\your theme name here
    4. Inside each folder you add the picture resources you would like to use for each numbered the same as they are in the explorer.exe, explorerframe.dll and Shell32.dll. These resources must be in png format not bitmap. So example explorer.exe for the start orb and user picture frame, the numbers for these in the explorer.exe are 6801, 6805, 6809, 7013. Add those picture resources to the explorer.exe folder and place it inside your theme folder.
    as shown below in screen shots:
    [Only registered and activated users can see links. ][Only registered and activated users can see links. ][Only registered and activated users can see links. ]
    For the explorer.exe folder you can also add the user frame png like so:
    this would be image 7013 in the explorer.exe folder
    Also in the Shell32.dll folder you can add images for icons in the shell32.dll as pngs there are many icons in the shell32.dll so I wont go into listing them all here but you may add images as 256x256 pngs for the icons in the shell32.dll just make sure to number them correctly as in the shell32.dll ie. 1 in the shell32.dll in the icons folder would be 1.png image in your shell32.dll folder
    5. Then just select your theme in the personalization menu and now your start orb will be changed, your explorerframe buttons and other images in the explorer frame, along with the navigation panel in system properties will now all be changed to the images you have placed in those 3 folders in your theme folder. This applies to any theme all you have to do is apply the theme normally. No more editing dll's to replace your images.
    6. This applies to even the aero theme that is the default on windows 7.
    Enjoy the theme resource changer
    Information
    Update: 21/04/2011 Thought I had fixed the problem with the drive letter but in case you are still having any problems getting theme resource changer to work then use this reg fix.
    Mad--Rabbit is offline
    Nov 2010
    6
    Re: How to use theme resource changer
    Great tutorial and great program. I'm going to use it straight away!
    jayarte is offline
    Nov 2010
    50
    I am currently using VistaGlazz theme patcher, which has worked fairly well, but doesn't always use the theme's start orbs, etc (so I've been doing them separately with StartOrbz). Anyway, the software you have described sounds much simpler, and more effective, but what do I do about the fact that currently VistaGlazz has been applied? Would I just uninstall it? Or have to change some files?
    Any advice you could give would be much appreciated.
    Thanks,
    Jay
    p.s. If I do uninstall it, what would happen to the themes which were working fine using VistaGlazz?
    Big V is offline
    A Supreme God
    Feb 2010
    Cornfeilds of Indiana
    2,698
    21 Post(s)
    297 Thread(s)
    i have both vista glass and theme resource changer installed with no problems
    jayarte is offline
    Nov 2010
    50
    Ah, I understand now, I obviously had misunderstood exactly what theme resource changer does. Thanks for the posts, guys, now to try it out ^^
    jayarte is offline
    Nov 2010
    50
    Actually, sorry to be a bit thick, but where do I get the images from? Also, some of my themes come with icon, navigation buttons etc, but they just don't get applied. And when I tried doing it once (following instructions by theme maker) by altering shell32.dll to shell32.dllbak, I crashed my pc because I was tired (and stupid, I admit) and missed out the "."
  1. Theme Resource Changer no more dll editing..
    By razorsedge in forum Theme Patchers
    Last Post: 03-10-2019, 10:22 PM
  2. Need Help with Theme Resource Changer
    By edee in forum Requests
    Last Post: 12-18-2011, 08:24 AM
  3. I Need Help with Theme Resource Changer
    By Elmo56 in forum Requests
    Last Post: 09-05-2011, 02:01 PM
  4. Theme Resource Changer no more dll editing..
    By razorsedge in forum General Windows 7 Customization
    Last Post: 01-01-1970, 12:00 AM
