Results 7 to 12 of 97
November 16th, 2010 04:21 AM #1
How to use theme resource changer
Theme Resource Changer Instructions
Theme Resource changer eliminates having to edit dll or exe files to replace the images in your explorer.exe, explorerframe.dll
and your shell32.dll.
1. To use the Theme resource changer download and run the Theme Resource Changer.exe x86 or x64 depending on what operating system you are using. Theme resource changer can be found here: https://virtualcustoms.net/showthread...-dll-editing..
2. After installation it will automatically restart explorer and you are set you only have to apply this just the one time and it will work for any theme that you setup to use it with.
3. To set your themes to use the Theme Resource Changer all that is needed is to make 3 folders inside your theme folder, with these names
explorer.exe
explorerframe.dll
Shell32.dll
like in the screen shot below:
Attachment 38541
These folders go inside your theme folder you have in windows\resources\themes\your theme name here
4. Inside each folder you add the picture resources you would like to use for each numbered the same as they are in the explorer.exe, explorerframe.dll and Shell32.dll. These resources must be in png format not bitmap. So example explorer.exe for the start orb and user picture frame, the numbers for these in the explorer.exe are 6801, 6805, 6809, 7013. Add those picture resources to the explorer.exe folder and place it inside your theme folder.
as shown below in screen shots:
Attachment 38542Attachment 38543Attachment 38544
For the explorer.exe folder you can also add the user frame png like so:
Attachment 38545
this would be image 7013 in the explorer.exe folder
Also in the Shell32.dll folder you can add images for icons in the shell32.dll as pngs there are many icons in the shell32.dll so I wont go into listing them all here but you may add images as 256x256 pngs for the icons in the shell32.dll just make sure to number them correctly as in the shell32.dll ie. 1 in the shell32.dll in the icons folder would be 1.png image in your shell32.dll folder
Attachment 38546
5. Then just select your theme in the personalization menu and now your start orb will be changed, your explorerframe buttons and other images in the explorer frame, along with the navigation panel in system properties will now all be changed to the images you have placed in those 3 folders in your theme folder. This applies to any theme all you have to do is apply the theme normally. No more editing dll's to replace your images.
6. This applies to even the aero theme that is the default on windows 7.
Enjoy the theme resource changer
InformationUpdate: 21/04/2011 Thought I had fixed the problem with the drive letter but in case you are still having any problems getting theme resource changer to work then use this reg fix.
Attachment 42088
Theme Resource Changer no more dll editing..
By razorsedge in forum Theme PatchersReplies: 126Last Post: December 17th, 2021, 03:45 AM -
Need Help with Theme Resource Changer
By edee in forum RequestsReplies: 5Last Post: December 18th, 2011, 07:24 AM -
I Need Help with Theme Resource Changer
By Elmo56 in forum RequestsReplies: 4Last Post: September 5th, 2011, 02:01 PM -
By razorsedge in forum News & ReviewsReplies: 2Last Post: December 31st, 1969, 11:00 PM
