Page 1 of 2 12 LastLast
Results 1 to 8 of 9
    soupiechef is offline
    Nov 2010
    9
    Need help finding resources in wsb
    I've been tweaking this windows 7 theme for a few weeks now, yet I cannot for the life of me find the resources I need to edit.
    I can't find the background color for the 1st box labeled, I thought it might be a rebar resource but I couldn't find one that works.
    The other 3 I'm merely looking for text colors, although I was not entirely sure if the drop down address menu was a problem.
    Thanks in advance!
    nofx1994 is online now
    Overlord
    Nov 2009
    Hillbillie Hell
    37
    1,050
    5 Post(s)
    65 Thread(s)
    Re: Need help finding resources in wsb
    ok first one not sure about but the second one that is
    Lists, Menus & Tabs > Menu > PopUpBackground
    Lists, Menus & Tabs > Menu > PopUpItem > Normal
    Lists, Menus & Tabs > Menu > PopUpItem > Disabled
    and the third one is that when you move something hard to tell what that one is
    bgjerlow designs is offline
    Denmark
    18
    557
    1 Thread(s)
    3 and 4 is Explorer & Shell > Shell > DragDrop
    You can edit the highlight text colors inside each sub category from Copy to None. Each of these will change something, so it's just about changing them all or trying your way
    bongo is offline
    Nov 2009
    Iowa
    111
    4 Thread(s)
    #1 I do not know
    #2 that text cannot be changed if that is the dropdown menu from the address bar
    #3 & 4 look at the 1st post on this page [Only registered and activated users can see links. ]
    Here is a maps Dave Serior put together that is great [Only registered and activated users can see links. ]
    Jerry
    Dave Senior is offline
    Mar 2010
    397
    8 Thread(s)
    1- without knowing the app, hard to tell but try these-
    Buttons, Boxes & Controls > Boxes > ComboBox > Border
    Buttons, Boxes & Controls > Boxes > ComboBox > ReadOnly
    Buttons, Boxes & Controls > Boxes > ComboBox > DropDownButtonRight
    if its none of those just go through these, you may get lucky
    Buttons, Boxes & Controls > Boxes (all the images under this class)
    if that fails post the name of the app for "1" it will help us track the location
    Nov 2010
    9
    First, I'd like to thank everyone for the quick replies sergio's advice for changing the copy text worked perfectly, but I wasn't able to change the address drop down menu font color in "2" or the background color in the "1" box (which is the old wordpad from vista, sorry for being so vague, it completely slipped my mind!)
    As far as what bongo said, I had unfortunately read in other places that the address bar font color was something that could not be changed. I tried nofx's fixes as well, but they didn't seem to affect my theme at all... I also tried adding a color:textcolor attribute, but to no avail. If it's not possible to change the font text color, what is the resource for editing the background color? I would just like a contrast between the text and the background in that drop down menu.
    Thanks for the replies though, I really appreciate the help as this has been something that has been in the back of my mind for weeks!
  7. #7
    bongo is offline
    Nov 2009
    Iowa
    111
    4 Thread(s)
    That background is at Lists, Menus & Tabs > Menu > PopUpBackground
    Lists, Menus & Tabs > Menu > PopUpBorders
  8. #8
    Nov 2010
    9
    Quote Originally Posted by bongo View Post
    Thanks for the reply, unfortunately it seems like it only affects the right-click context menu for me. I don't know if that's something wrong with my theme, but I can't seem to find anything that affects the address bar dropdown menu...
  1. Help finding two background color locations.
    By undine in forum Miscellaneous questions
    Last Post: 05-05-2010, 03:50 PM
