Results 7 to 12 of 14
December 7th, 2010 01:10 AM #1
- Nov 2009
- usa
- 106
- 3 Thread(s)
Windows Style Builder 1.6 Ideas List - Any suggestions?
i found this information on web sight
on: January 22, 2010, 10:51:26 pm »
WSB 1.6 Ideas:
•• Goto have the ability to use the same path as difftool (<ButtonStyle>.<1>.<1>)
•• Goto have the ability to use DirectUI like paths (BUTTONSTYLE, 1, 1)
•• COLORIZATIONCOLOR:INT show color rather than integer / Use color picker
•• Font replacer (Replace font that matches x with y)
•• Font preview in property box
•• Color replacer (Replace color that matches x with y)
•• Image alpha tagger1
•• DWMWindowIsChanged::Bool2
•• Font picker automatically opens upon adding
•• Color picker automatically opens upon adding
•• When opening a theme copy Shell to %temp%
•• Open help in new window button.
•• On Test/Apply reuse last DWM Colorization Color.
1On import VSB will add a value into the image to represent whether or not the image has been alpha fixed. When export then imported again VSB will check this value then either import by its default function or import and skip the alpha conversion based on this value.
2WSB will check if the end-user has modified any classes in DWMWindow. If not the stream will be ignored on compile preventing pixel alignment errors.
« Last Edit: January 23, 2010, 09:18:18 pm by Panda X »
https://vistastylebuilder.com/forum/inde ... opic=912.0
Help With Windows Style Builder
By KaddirB in forum General Windows 10 CustomizationReplies: 2Last Post: March 25th, 2019, 11:29 PM -
I need some help with Windows Style Builder
By Larmes de Crocodile in forum Miscellaneous questionsReplies: 11Last Post: March 23rd, 2013, 09:55 PM -
Windows Style Builder Help
By cube069 in forum Miscellaneous questionsReplies: 0Last Post: June 4th, 2011, 11:43 AM -
Windows Style Builder 1.5
By Mbrys331 in forum WSB ErrorsReplies: 1Last Post: December 3rd, 2010, 10:58 PM -
Please help windows 7 style builder
By Fask in forum Miscellaneous questionsReplies: 1Last Post: May 14th, 2010, 05:38 PM
