December 10th, 2010 11:23 PM #1
How to take full control of Windows 7 Registry keys
Windows operating system will not allow you to make changes in certain system critical registry keys. Nevertheless, if you want to make changes even in such registry keys, you will have to take full control of these keys before Windows will allow you to make or save the changes.
Before you open the registry editor as admin, first backup your Windows registry and create a system restore point.
Next navigate to the registry key where you want to make the change.
If you try to make changes to such system critical registry keys, you will get the following error:
Attachment 39406
Error Creating Key – Cannot create key: You do not have the requisite permission to create a new key.
Close this error dialog box and right click on the registry key where you want to make the changes and click on Permissions.
Attachment 39407
In the Permissions box, under its sole security tab, highlight your own Administrators account and then check the box under Full Control – Allow.
Click Apply > OK.
If it still doesn’t work and you get the following security warning – Unable to save permission changes, do the following.
Attachment 39408
Open the Permissions windows again and click on Advanced button instead, and click on the Owner tab.
Attachment 39409
Do you see another owner like say, TrustedInstaller ? If so, change owner to your Name.
Click Apply > OK.
NOW again in the Permissions box, under its sole security tab, highlight your own Administrators account and then check the box under Full Control – Allow. Click Apply > OK.Last edited by Big V; August 18th, 2011 at 04:53 AM.
Windows 8 registry Tweaks
By razorsedge in forum Help and SupportReplies: 0Last Post: December 8th, 2012, 11:55 PM -
Pin Control Panel To Taskbar To Quickly Access Control Panel In Windows 8
By razorsedge in forum Help and SupportReplies: 0Last Post: December 8th, 2012, 03:44 AM -
Windows Registry shell extension
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: January 26th, 2011, 05:25 AM -
How To Delete Windows 7 Product Key From Registry
By razorsedge in forum General TutorialsReplies: 0Last Post: December 11th, 2010, 12:01 AM -
Disable Autorun Functionality in Windows Using Registry Edit
By razorsedge in forum Setup TutorialsReplies: 0Last Post: July 29th, 2010, 12:37 AM
Post Your Windows 11...
