January 6th, 2011 11:53 PM #1
How to Make a 3D Cube Icon (the easy way)
Attachment 40123This is the easiest and fastest way I've come up with to make 3d cube and ball icons.
The only program needed is Paint.Net found here https://www.getpaint.net/
You will also need the Shape 3D plugin from here: https://mkt.t-cat.biz/pdn/3.htm#3
To install the plugin cpoy the .dll to the"Crograms Files\Paint.Net\Effects folder.
You will also need some .png icons to place on your cubes(or sphere).Remember when using
someone else's work that you need to respect the usage rights(license)they have established for it.
Step 1
After opening paint.net create a new canvas 600 x600.
To do this go to the "Image" in the top toolbar,
Select Resize uncheck "maintain aspect ratio",enter 600 in the Pixel width and height boxes
Now choose a backgound color and fill the canvas using the paintbucket tool.
Step 2
From the "Layers" tab, choose "import from file",choose the icon you want to use,
Stretch the icon into postion by dragging the little white boxes in the layer outline of the layer
Make sure its centered,When you get it where you want it hit the "Deselect button"
Now in the layers box hit the "merge layer dowm"button
Attachment 40120
Step 3
Now go to "Effects" tab,then down to "Render" choose "Shape3d",
In the the window that opens pick the "Box" tab.You will see a ton of adjustments,
We are only going to use a few:
Object Rotation,use the 3 dials to angle and rotate your cube
Scaling and Reset Position,use these to resize your cube
if rotating it causes it to go outside the canvas frame
Lighting,in the section there is 3 adjustment you can make easily make
Strenght of Light,Ambient Lighting and Diffuse Reflection Rate
There's others but I'm just keep things simple.Go ahead and play around until
your happy with the look of your cube then hit"ok"
Attachment 40126
Step 4
From the top toollbar hit "File" then "save as",name your new icon,
make sure it's in .png format and hit "Save"
To convert the new icon to a usable .png and to a .ico I use https://iconverticons.com/
It's a free online icon convertor,just upload your image and it does all the work,
then download the converted icon in the formats you want.
Attachment 40122
That's it,done! Enjoy
For a 3D ball the steps are the same excpt:
instead of Box use Sphere and instead of stretching the icon layer you need to shrink it down to about
300 in height and 150 in width.You'll have to play around a bit to get the right look.
Attachment 40121Last edited by Big V; August 12th, 2011 at 01:59 AM.
How to make a custom 7tsp icon pack
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 20Last Post: April 13th, 2023, 04:24 AM -
How to make a custom icon pack
By luffybo in forum 7tsp Icon PacksReplies: 0Last Post: March 31st, 2014, 09:07 AM -
VC in a cube
By XXXxxxXXX in forum Wallpapers by Other Great ArtistsReplies: 7Last Post: January 3rd, 2012, 12:17 PM -
Skull VS Cube.
By sete in forum Wallpapers Posted by seteReplies: 6Last Post: October 13th, 2011, 07:50 AM -
multicolor cube
By RIMARU in forum Wallpapers Posted by RIMARUReplies: 6Last Post: March 7th, 2011, 03:47 PM
