Results 1 to 5 of 5
    Mbrys331 is offline
    Nov 2009
    usa
    109
    2 Thread(s)
    Win7BootUpdater.exe
    I found this [Only registered and activated users can see links. ]
    A program that makes it easy to update the Windows 7 boot animation and text. design cool animations!
    It requires the Microsoft .NET Framework 2.0 and the Microsoft WIM library.
    [b]Details ¶Current Version: v0 Alpha 9 (v0.0.0.9)
    Features ¶
    •Modifies the boot animation
    •Modifies the boot text "Starting Windows" and "© Microsoft Corporation"
    •Will create the animation from 105 BMP, PNG, GIF, or TIFF images or uses a single (non-animated) image
    •Does not require any other applications (like ImageX)
    •Designed to be idiot-proof by having numerous checks
    •Automatically backs-up the modified files
    •Does not require test-signing or no-integrity-checks to be enabled
    •Works for all versions of Windows 7: any language, any edition, 32-bit or 64-bit
    •Works even if your setup has the hidden "System Reserved" partition
    How to Use for more information.
    How to Use ¶
    Prerequisites ¶
    If you have Windows 7 then you are good to go! The WIM library is included with Windows 7. If you will be running this on Windows Vista or earlier you will need to follow some additional directions.
    The Animation ¶
    If you choose to change the animation you will have to make an animation! The animation can be one long BMP that is 200x21000px or a folder containing 105 BMPs, PNGs, GIFs, or TIFs. The files will be played in alphabetical order (so if you are numbering them, use the same number of digits for all numbers (e.g. 000, 001, ..., 103, 104). Here are the details about the animation:
    •105 frames
    •15 frames / sec
    •First 4 seconds play once then the last 3 seconds play in a loop
    •Each frame is 200x200px
    The GUI ¶
    To use the GUI, simply double-click the program "Win7BootUpdater.exe". The program will request administrator privileges. Make all the changes you wish to make to the boot screen. A preview on the right hand side will show you approximately how it will look (note: the text is not quite positioned correctly). For the background color of the entire screen you are limited to the 16 'custom' colors. Picking a different color will cause it to find the closest possible color. In the 'Options' menu you can also adjust the files which are modified (bootres.dll, winload.exe, winload.exe.mui, and bootmgr). You must use un-altered files. You can also restore the backups created by the program from there. If you would like to share your boot screen design, you can save a boot skin. The boot skin will embed all necessary data including animation and font.
    The Command Line ¶
    Currently disabled, but coming again soon!
    Recovering winload.exe Manually ¶
    If you get stuck forever in Windows Recovery Environment then you need to manually restore winload.exe. Here are the directions:
    1.Once you enter Windows Recovery Environment press "Cancel" right away (while it is still scanning)
    2.Click "Yes" on the warning that pops up
    3.Click "View advanced options for system recovery and support"
    4.Select your keyboard types and click "Next>"
    5.Select an account (not "HomeGroupUser$") and enter any necessary password and click "Ok"
    6.Click "Command Prompt" (the last option)
    7.Enter the following commands:
    1.d:2.cd \Windows\System323.del winload.exe4.ren "winload - Backup.exe" winload.exe5.cd \Windows\Boot\PCAT6.del bootmgr7.ren "bootmgr - Backup" bootmgr8.exit8.Click "Restart"
    {winload.exe} Before
    {winload.exe.mui} Before
    {winload - Backup.exe} After
    {winload.exe - Backup.mui} After
    Windows is a registered trademark of Microsoft Corporation in the United States and other countries.
    Bristow is offline
    Jul 2010
    Pacific Ring of Fire
    120
    Re: Win7BootUpdater.exe
    Thanks for the share MBrys331
    Spiderman is offline
    Mar 2012
    Los Angeles
    14
    6 Thread(s)
    the rar file seams to be corrupted but thank you for the share.
    Big V is offline
    A Supreme God
    Feb 2010
    Cornfeilds of Indiana
    2,786
    21 Post(s)
    266 Thread(s)
    Quote Originally Posted by Spiderman View Post
    use the link in first line of the post
    edit: archive fixed in first post
    Mar 2012
    Los Angeles
    14
    6 Thread(s)
    Quote Originally Posted by Big V View Post
    AHHHHHHA Thank you
