January 14th, 2011 01:30 AM #1
25+ Best Free Tools To Customize Windows 7
1. Theme resource Changer: A one time install tool that will change your start orb, navigation panel, shell32.dll icons and all explorerframe images and start menu pic frame when you apply any theme that has been setup for use with it.
2. Windows 7 Boot Updater: One of the advanced tools available for the latest version of Windows which makes the impossible possible. Read our how to change Windows 7 boot screen guide to learn to how to change the default boot screen animation in Windows 7.
Attachment 40215
3. Logon Workshop: There are tens of free tools available to change the default logon background. You can even manually change the logon screen background with a simple registry trick. But this tool offers some advanced options to customize logon buttons, font color, and more.
Attachment 40216
4.Windows 7 Start Orb Changer v4: Use this tool to create and change the default Start orb of Windows 7 in a few clicks.
Attachment 40218
5. Taskbar Transizer: Want to make your Windows 7 Taskbar and Start menu transparent? Taskbar Transizer allows you set a custom transparency level for Taskbar and Start menu.
Attachment 40220
6. DreamScene Activator: As you know, DreamScene feature is not available in Windows 7. Use this tiny tool to enable the same in the latest version of Windows.
Attachment 40221
7. Logon Screen Rotator: Unlike other logon screen tweaking tools, this tool changes the logon screen background every time you login.
Attachment 40224
8. VistaGlazz & Black Glass Enhanced: Tools that enables you install third-party visual styles in Windows 7.
VistaGlazz
Attachment 40226
Attachment 40227
9. CustoPack Tools: An awesome application to customize icons, cursors, sounds, folder icons, logon backgrounds, and visual styles in Windows 7.
Attachment 40228
10. WMP12 Library Background Changer: Changes the default library background of Windows Media Player in Windows 7.
Attachment 40230
11. Media Center Studio: Customize Windows Media Center by applying new themes. It also lets you create your own Media Center themes.
Attachment 40231
12. Taskbar Color Changer: Another tool to customize the superbar. Lets you set a custom color for Taskbar.
Attachment 40232
13. Copy/Delete Animation Modder: An excellent tool to change the default copy, move, and delete animations in the latest version of Windows.
Attachment 40233
14. Drive Icon Changer: Use this tool to replace the default drive icons in explorer with custom ones.
Attachment 40235
15. Folderico: Though you can change the default folder icon without the help of third-party tool, it’s difficult to change the color. Folderico helps you change the color of a folder right from context menu.
Attachment 40238
16. Task Manager Modder: Got bored with the default look of Task Manager? Take the help of this tool to easily change its color.
Attachment 40239
17. Windows 7 Aero Blur Tweaker: As the name reveals, it enables you change the aero blur settings. Read our review about Aero Blur Tweaker to read more about this tool.
Attachment 40242
18. Windows 7 Task Pane Changer: Want to change the taskpane background that appear in Control Panel and in some other parts of Windows? Download and use this tool to quickly change the default taskpane background with a custom one.
Attachment 40243
19. Navigation Button Colorizer: Change the color of explorer navigation buttons with the help of this free tool. It’s portable and easy-to-use.
Attachment 40245
20. 7Conifier: This is another tool to customize your Windows 7 Taskbar. It quickly replaces the application icons in Taskbar and Start menu.
Attachment 40246
21. Windows 7 Start Menu User Picture Remover: Don’t want to see the user picture in Start menu? Use this utility to remove the user picture from the Start menu.
Attachment 40247
22. Windows 7 Folder Background Changer: Like in XP and Vista, you can set a custom background for a folder in Windows 7 as well. Use this tool to replace the default white background in a folder with a custom picture.
Attachment 40248
23. Theme Manager: If you want to install a third-party theme in Windows 7, you will need to manually replace a few system files as well. Theme Manager helps you install new visual styles by automatically replacing the default system files with customized ones.
Attachment 40249
24. Taskbar Thumbnail Tweaker: The thumbnail preview that appears when you hover the mouse cursor over an opened application in Taskbar can be customized using this tool.
Attachment 40250
25. Windows 7 Tray Icons Changer: A simple tool to replace the default network, firewall and volume icons in notification area (system tray) with custom ones.
Attachment 40251
26. AeroTuner: Lets you change Aero color, aero stripes, and blur with a few mouse clicks.
Attachment 40252
27. 7 Library Icons Changer: Replace the default library icons with the help of this free tool.
Attachment 40254
Customize Windows apps
By tistou77 in forum General Windows 7 CustomizationReplies: 0Last Post: February 27th, 2013, 02:19 PM -
Microsoft Launches Free Tools to Help Users Create Windows 8 Apps
By razorsedge in forum Help and SupportReplies: 0Last Post: December 7th, 2012, 12:57 AM -
How to master the Windows 8 admin tools
By razorsedge in forum Tips and TricksReplies: 0Last Post: December 7th, 2012, 12:54 AM -
Customize Windows 7 installation with RT Se7en Lite
By razorsedge in forum MiscellaneousReplies: 1Last Post: May 28th, 2012, 05:13 AM
ROG Tweak Theme for...
