Results 1 to 6 of 6
Thread: Taskbar skin? Share
    Gonsu is offline
    Jan 2011
    2
    Taskbar skin?
    Hi,
    Im new and feel free to insult right after this message since im almost 100% sure this has been answered before, but i couldnt find it.
    Im curious how you change ur taskbar, the skin of it etc. No matter how many guides i read , none really solves my problem.
    This was made from a guy named FireBlade, from Rocketdock. And his little to turtorial was simply this.
    But everyone kept commenting how to get the actual skin i guess.
    I did follow this guide, and this is how it gets.
    While his looked like this.
    So i guess im asking, can anyone guide me through this step by step?
    Would appreciate it alot, or simply guide me to the guide if there exists one >.<
    Thanks.
    Mr GRiM is offline
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,546
    526 Thread(s)
    Re: Taskbar skin?
    You need to install a theme from our windows 7 theme section first to change the taskbar, that guide you have is just to center the icons on the taskbar, you will also have to enable custom themes, I us UxStyle Core to enable them and then install your theme and apply it in the personalization menu.
    If you want a easy theme to install try my Blade theme, I made a exe to install the theme so you don't have to worry about where to install it, it will do it all for you and apply it as well, you will still need to install UxStyle Core though or it will not work.
    Gonsu is offline
    Jan 2011
    2
    Re: Taskbar skin?
    Thanks for reply,
    But im afriad i still have the same problem.
    I downloaded and installed UxStyle Core. ( i havent entered the program yet , i couldnt find the start icon , incase i have to to change somthing in there. But i did install it )
    After that i picked a W7 theme from lefty1981 called ElegantX1.0.
    His picture. (Notice his taskbar)
    And mine.
    The picture isnt as big but you can clearly see the dots down the taskbar, and i cant get it to look like his.
    So everything seems to work except the taskbar, just like before. And thats whats bother me :/
    Thanks.
    Mr GRiM is offline
    Bringer of Death
    36
    4,546
    526 Thread(s)
    Re: Taskbar skin?
    Lock your taskbar to remove the dotted lines, for the start button you will either have to install Theme Resource Changer and find a theme that uses it like my Blade theme, it also installs that with Blade so that would kill 2 birds, or you could download the start button changer from Kishan Bagaria [Only registered and activated users can see links. ]
    selluminis is offline
    Jan 2011
    14
    Re: Taskbar skin?
    Quote Originally Posted by Mr GRiM
    Where do we get the UxStyle Core from? I wonder if this is why I am having issues getting the rest of the icons to change on Blade.
    Mr GRiM is offline
    Bringer of Death
    36
    4,546
    526 Thread(s)
    Re: Taskbar skin?
    Quote Originally Posted by selluminis
    Information
    Very Important!!!
    UxStyleCore
  1. Change Taskbar for another taskbar
    By crisis42 in forum Taskbar
    Last Post: 06-29-2011, 04:36 PM
  2. Replies: 0
    Last Post: 05-19-2011, 09:16 PM
  3. COMA Winamp Skin by ~panda-skin
    By razorsedge in forum WinAmp Skins
    Last Post: 04-18-2011, 06:54 AM
  4. Replies: 0
    Last Post: 04-10-2011, 06:25 PM
  5. Taskbar
    By Mbrys331 in forum MBrys331 Windows 7 Themes
    Last Post: 01-22-2011, 03:21 PM
