March 8th, 2011 04:10 PM #1
How To Rebuild Icon Cache For Windows Vista & 7
Ok, if you are having problems with an icon that is blank or looking kinda odd for program you have installed on you pc, try uninstalling the offending program and then re install it, this will fix the issue normally.
However, sometimes it isn't that easy when a lot or all icons are blank. This is due to the icon cache being corrupted which can be caused by a number of things.
This will help guide you on how to correct your issue regarding blank icons by Deleting & rebuilding the icon cache;
Ok, to be able to rebuild the icon cache you will need to locate and delete the file which will be hidden by default. (step 1) Firstly open Computer by going to > Start > Computer Is Located On Right Side of Menu;
Attachment 41113
(step 2) In the new Window Click Tools from the Menu > Select Folder Option;
Attachment 41114
(step 3) Now click the View tab > Select Show Hidden Files Folders and Drives and click Apply;
Attachment 41115
(step 4) Now go to computer as you did in step 1 then type in the address bar > %username%\AppData\Local and press Enter:
Now locate the Icon Cache File and simply delete it;
Attachment 41116
Now all you need to do now is restart your PC and this will automatically rebuild the Icon Cache to its normal self.
Thats it done, all your icons should be displayed as normal.Last edited by Big V; August 12th, 2011 at 05:03 AM.
Restart Explorer & Rebuild Icon Cache tweaks for Right Click
By razorsedge in forum Installation & SetupReplies: 7Last Post: January 16th, 2013, 08:53 PM -
Rebuild Icon Cache v2 by ~gokool
By razorsedge in forum Icon appsReplies: 0Last Post: November 18th, 2010, 02:14 AM -
[Howto] Clear The Windows Icon Cache.
By Generator2013 in forum General TutorialsReplies: 5Last Post: October 19th, 2010, 04:46 PM -
Icon Cache Rebuilder by Lee Whittington
By razorsedge in forum Icon appsReplies: 0Last Post: August 21st, 2010, 03:36 PM -
Rebuild Icon Cache v0.7b
By razorsedge in forum Icon appsReplies: 0Last Post: July 31st, 2010, 11:21 AM
