Originally Posted by
JohnDay
Ok well you say im a noob but how much if a newbie to PC stuff i dont know so ill just go through everything i can think of, just skip the bits that are common place for you. Im not being condecending with any of this explanation just trying to explain as much as i can as some say im a noob and they really are PC illiterate and some say im a noob and can do just about everything.
First off you need to Patch Windows, if you have already done this then skip this bit.
Google for Universal Theme Patcher and download it or find it on this forum if you wish.
Use restore point and make a backup of windows, it is advisable to make regular backups with restore point anyway.
Double click Universal Theme Patcher and click patch system.
Let it do its thing and then restart windows, it may take a little time for it to patch everything it needs to patch so be patient and let it finish. If windows still performs as it should then all is good and you can move on, if not use the restore point and try again.
Ok to the Theme
If you havnt done so already, the files need to be extracted with either 7zip or winrar. If you dont have anything to unzip with, then download either of those 2 programs and isntall them, you can get both from FileHippo.com
Extract the theme files anywhere, on the desktop or a specific folder of your choosing it doesnt matter.
Inside you will find a file called !Things to do First
Open that file and install Theme Resource Changer, X86 is 32bit system and X64 for 64bit system, if you have already done this for other themes then you dont need to do it again.
Open the font folder and extract the font, then double click the font and choose isntall font.
Browse back out of there and into the Theme Folder
Double click the executable in there and follow the instructions. Just like a normal installer. DO NOT change the install location it is already the correct place, if you do change it the theme will not work.
The theme should now be there for you to use. If not restart windows again then check the personalize menu again for the theme.
If you want to use the Icons then just install them from the Icon Set folder just as you did with the theme.
