Thread: Windows 7 Color Changer Share
    razorsedge is offline
    The Sci-Fighter
    Oct 2009
    39
    4,849
    16 Post(s)
    287 Thread(s)
    Windows 7 Color Changer is a simple application that lets you set a window color for every desktop background picture.
    When you install this application, a small icon will appear in the notification area of the taskbar. Right-click on the icon and select Setup wallpapers option to start adding new wallpapers to the slideshow.
    How to use this tool:
    # Open Setup wallpapers window and click Open Image button to a add a new wallpaper to the slideshow.
    # Next, click Autodetect button to automatically set a color to the wallpaper. You can also use Select color option to add your desired color.
    # Finally click Add as new button to add the picture with theme color.
    # Repeat the above steps to add more desktop backgrounds to the slideshow list.
    # Once done, click Set button to run your new desktop slideshow.
    If you donít want to manually add wallpapers to the slideshow, simply switch to the Auto tab and browse to a folder to automatically add all pictures to the slideshow.
    Please note that this application canít create a theme pack for you.
  1. Windows 7 Start Orb Changer v4
    By razorsedge in forum Start Orbs
    Last Post: 07-01-2012, 06:39 PM
  2. Windows 7 Logon Branding Changer
    By razorsedge in forum Logon
    Last Post: 06-11-2012, 11:50 PM
  3. Windows 7 branding changer by ~myjuman
    Last Post: 11-09-2011, 11:49 PM
  4. Problems with windows 7 start orb changer
    By Blackheart in forum Software
    Last Post: 08-20-2010, 06:47 PM
  5. Windows 7 Taskbar Color Changer
    By razorsedge in forum Taskbar
    Last Post: 08-12-2010, 10:51 AM
