Page 1 of 2 12 LastLast
Results 1 to 8 of 10
    zeno101 is offline
    May 2011
    4
    Bios POST screen
    When you buy a brand name pc and switch on it displays a screen with eg HP as it runs through POST prior to reaching the starting windows screen. Having just recently built a pc (first go) for home use, I get Bios/mobo details before it goes to starting windows screen. Is it possible to change this for an image of my own choice or am I better off leaving it as it is?
    bgjerlow designs is offline
    Denmark
    18
    557
    1 Thread(s)
    Re: Bios POST screen
    Hmm, that's a good question. As far as I know it's not possible to do that, and even if it is, it's not going to be a "walk in the park" doing it, since you will have to modify your BIOS most likely and that can cause huge problems if you make a mistake whilst doing that.
    Mr GRiM is online now
    Bringer of Death
    Cairns, FNQ, Australia
    35
    4,167
    144 Thread(s)
    Yeah I think you would have to be a very advanced user to even attempt flashing the bios to add a custom image in there, I think it would be best to forget about that idea
    zeno101 is offline
    May 2011
    4
    There is a utility on the support disc called face wizard (gigabyte mobo) which apparently can change the POST screen, except I have 2 probs with this. The image needs to be in BMP format and 16/256 colour, 640 x480. Size and format I can do but not sure how to change it down fron 24 bit. Also waiting for an answer from the gigabyte support website as surely they must know how to do it, failing that I'll just contact other makers and maybe they shed some light. Thanks for your help and if I get an answer will let you know the outcome.
    Big V is offline
    A Supreme God
    Feb 2010
    Cornfeilds of Indiana
    2,786
    21 Post(s)
    257 Thread(s)
    Face wizard works great if you have a gigabyte mobo and very simple to use. Just load the image then restart your done.I don't recommend doing this on a everyday basis since you are messing with the bios and if you have a conflict you run the risk of bricking your system Just make sure it right size and format or you will have problems. The Version i have will do PCX or BMP format images smaller than 640x480
    CrazySouthernBoy
    Guest
    Quote Originally Posted by zeno101 View Post
    You can open in Paint of Photoshop & Just re-size it to the right Specs & then save as what ever name you want it then just change the file Format to the right one you need.
  7. #7
    zeno101 is offline
    May 2011
    4
    I think the last 2 posters may have misunderstood what I actually want to do. Don't want to change the small image in top corner, but place my own pic (gigabyte image) across the whole screen. Its what all the companies do when they kick out their OEM machines with the company logo on the boot screen.
  8. #8
    CrazySouthernBoy
    Guest
    wait the boot screen like where it said Xp? or the BIOS screen?
    I use TuneUp to change my boot screen.
