Results 1 to 6 of 6
    Panda X is offline
    May 2011
    15
    The Base Project.
    As some of you may know, Base maps almost all hardcoded values from the theme's shellstyle.dll to the msstyles. This way you can have more control over your theme making it easier to make modifications without having to make modifications to the UIFile.
    This project is an ongoing community project. The idea is to continuously update Base with code/ideas from other themers that can be done within Shellstyle.dll. As of version 1.0.0 there aren't many changes to be made.
    So if you have any suggestions for additions to Base's Shellstyle post them here.
    You can download and get more info at [Only registered and activated users can see links. ]
    Mr GRiM is offline
    Bringer of Death
    Cairns, FNQ, Australia
    35
    4,222
    161 Thread(s)
    Re: The Base Project.
    Welcome to Virtual Customs Panda X, it's great to have someone with your knowledge and experience on the team
    This is a great little project you started, one thing you have to remember when using the base style I found out is to copy the base shellstyle.dll to the temp shell folder for testing or windows doesn't like it very much, I really want to start using this allot more as I have found myself editing the UIfile more and more recently to change text colours and content margins, only problem is I am good at making themes just not very good and programing so I don't really understand how I can go from editing the value in the UI file to doing that in the Base Style.
    Maybe if you post a little tutorial and some examples of the msstyle taking control of a couple of elements and then it might click on what I need to do, then I can start experimenting and contributing to this great little project.
    nofx1994 is offline
    Overlord
    Nov 2009
    Hillbillie Hell
    37
    1,054
    5 Post(s)
    67 Thread(s)
    sounds like a very cool little project you have going on here panda and as grim said the more knowledge about it the more that the builders here could help contribute to your project.
    Panda X is offline
    May 2011
    15
    Thanks for the welcome you guys. I'll write up some tutorials in a bit. Currently working on Foundation (an extension to Base) and playing around with that.
    Quote Originally Posted by [url=http://virtualcustoms.net/viewtopic.php?p=40301#p40301
    Mr GRiM » 23 May 2011, 20:23[/url]]copy the base shellstyle.dll to the temp shell folder for testing
    Hopefully that bug will be fixed in WSB 1.6. It's suppose to copy it automatically but it places it in the wrong directory.
    In the meantime if you would just like to mess around with the UIFile and see what happens you can read this quick guide on DUI: [Only registered and activated users can see links. ]
    Though if you do that make sure you make no typos or Explorer will throw a fit.
    razorsedge is offline
    Cyberfox Co Developer
    Oct 2009
    38
    4,792
    16 Post(s)
    113 Thread(s)
    This is great panda x thank you very much gald to see you here I remember a bit back messing with what u did here some what with mr grim was a bit confusing.
    But there is a lot of other edits in files as MR Grim was saying we have been doing and it seems as if this will give u the ability to do these edits in the msstyle itself that would be really great I look forward to keeping an eye out for this project
    Thank u
    bigcyco1 is offline
    Moderator
    Feb 2010
    Los Angeles, California.
    33
    1,791
    10 Post(s)
    59 Thread(s)
    Welcome panda x we are glad to have you!
  1. Blade Base
    By Mr GRiM in forum Base Theme Resources
    Last Post: 03-22-2013, 04:07 AM
