Results 1 to 3 of 3
Thread: Changing Explorer Share
    Synthetic is offline
    Mar 2010
    2
    1 Thread(s)
    Changing Explorer
    I tried downloading and installing "Take Ownership" to take ownership of "Explorer.exe" to change it for themes. It doesn't allow the context menu to be available while right-clicking on it, and even when I try to end task the explorer.exe and use a administrated command prompt I have access denied when trying to rename it. Does anyone have any clue how I can fix this so I can use custom themes?
    HaCkthEplAneT
    Guest
    Re: Changing Explorer
    to take ownership of explorer.exe you have to do it manually.
    right click explorer.exe and choose properties > security tab > now click the advanced button
    go to the owner tab > click edit > select your name from the list provided and click apply > click ok when the windows security box pops up > click ok one more time to close out the advance security settings window > click ok again
    when you get back to just your explorer.exe properties window click on edit > select your name from the list > check the box that says full control > apply > click yes on the windows security popup > then ok > and ok one more time to close out the properties box.
    you should now have ownership of explorer.exe. so you can right click and rename explorer.exe so you can replace it with another.
    Mar 2010
    2
    1 Thread(s)
    Thank you so much, this has been driving me nuts for such a long time.
  1. font not changing
    By bigdisney in forum Theme Issues
    Last Post: 11-01-2012, 06:20 AM
  2. need help changing background in explorer
    By elfenliedtopfan6 in forum Explorer and shell
    Last Post: 05-15-2012, 03:35 PM
  3. Add “Restart Explorer” Option in Desktop and Explorer Contex
    By razorsedge in forum Installation & Setup
    Last Post: 01-24-2011, 03:11 PM
  4. Explorer Button Color Changing App
    By Psych0t1c in forum Desktop
    Last Post: 01-31-2010, 03:12 PM
  5. Can anyone help in changing explorer boder colors
    By rockyp in forum Theme Building Questions
    Last Post: 01-27-2010, 02:27 PM
