Page 1 of 2 12 LastLast
Results 1 to 8 of 13
Thread: Issue with Theme Resource Manager Share
    hellfirefox is offline
    Jun 2011
    10
    4 Thread(s)
    Hey Guys,
    I'm new on this forum but I find it very interesting and usefull!
    So, I have a question for you
    When I turn on my computer, all the things controled by Theme Resource Manager do not work ( like orb, the window of the caracter, ect ...). To make it work, I need each time to go in Windows setting and select my theme again... I use Fusion Theme, and all the folders needed are created (like explorer.exe, shll32.dll ect ...).
    What can I do to fix it ?
    Thanks for your help and sorry for my english ( poor frenchy ^^).
    (I ve already searched on the web but I have not found a real solution...)
    XXXxxxXXX is offline
    tripleX
    Nov 2010
    Germany, Rheinland-Pfalz
    17
    296
    2 Post(s)
    17 Thread(s)
    Re: Issue with Theme Resource Manager
    I had a similar Problem. For me it was a wrong registry value at HKEY_CLASSES_ROOT\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\InprocServer32 . The value standart linked to the wrong path. Maybe this could help you, too.
    Jun 2011
    10
    4 Thread(s)
    Thx for your answer, but can you tell me with what value I have to change the key?
    I found nprocServer32 in :
    HKEY_CLASSES_ROOT\CLSID\{0000002F-0000-0000-C000-000000000046}\InprocServer32
    In, there are :
    Default C:\Windows\System32\oleaut32.dll
    ThreadingModel Both
    tripleX
    Nov 2010
    17
    296
    2 Post(s)
    17 Thread(s)
    I think this is the worng key. Isnt there the key HKEY_CLASSES_ROOT\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\InprocServer32 in your registry? If not you have to search for the path where you have installed Theme Resource Changer. If this doesn't bring any results, search for the Path without the driveletter. If this bring a result, change the value to the right path of theme recource changer.
    Jun 2011
    10
    4 Thread(s)
    I have finaly found HKEY_CLASSES_ROOT\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\InprocServer32 :afraid: ...
    It was writen in default : Program Files\Theme Resource Changer\ThemeResourceChanger.dll and this is the correct path of the .dll
    I have also tryed : C:\Program Files\Theme Resource Changer\ThemeResourceChanger.dll
    But still no result... ThemeResourceChanger still work only after theme reloading, and not when I start windows ...
    A last idea before I try to restore all my computer ? :grim:
    tripleX
    Nov 2010
    17
    296
    2 Post(s)
    17 Thread(s)
    Do you have disabled the taskplaner? Im not sure, but I think theme resource changer use this to run the dll. If you have disabled the taskplaner you could try to enable it. Maybe this helps.
    EDIT:
    I had just one more idea: if you use the start orb changer you have to restore the standart orb before you use a theme with theme resource changer.
  7. #7
    Jun 2011
    10
    4 Thread(s)
    I have never used the start orb changer ^^ and I haven't taskplaner process ...
    But I changed some dll with restorator so... Maybe I should restore all the dll I changed.
    The problem is that I don't remember all the dll I have modified...
    Thanks for your help but the only solution is probably to restore my computer
    And if that doesn't work, I ll give it a head shot
  8. #8
    _Deano_ is offline
    Jul 2010
    28
    425
    5 Thread(s)
    run command promt as administrator and type in sfc /scannow , this will bring your files back to default
  1. How to use theme resource changer
    By razorsedge in forum Theme & Extras Setup Tutorials
    Last Post: 06-23-2014, 02:20 PM
  2. Replies: 18
    Last Post: 07-10-2012, 07:03 PM
  3. Make a theme use theme resource changer
    By gor17981 in forum Theme Building Questions
    Last Post: 03-09-2012, 03:10 PM
  4. Need Help with Theme Resource Changer
    By edee in forum Requests
    Last Post: 12-18-2011, 07:24 AM
  5. Task Manager Issue Please Help
    By mandy in forum Windows Style Builder v1.5 Tutorials
    Last Post: 10-12-2010, 11:49 AM
