User Tag List
Page 2 of 2 FirstFirst 12
Results 9 to 13 of 13
Thread: Issue with Theme Resource Manager Share
  1. #9
    Big V is offline
    A Supreme God
    Feb 2010
    Cornfeilds of Indiana
    2,787
    Post Thanks / Like
    21 Post(s)
    296 Thread(s)
    Re: Issue with Theme Resource Manager
    Have you tried running sfc /scannow (do not forget the space between c and / in the promt box) in a command promt this will restore all your system files to the original state. You will need to repatch you system files after this for 3rd third party themes. Theme resource changer does not like to work if you have previously modified your files with other software like start orb changer
  2. #10
    hellfirefox is offline
    Jun 2011
    10
    Post Thanks / Like
    4 Thread(s)
    Quote Originally Posted by _Deano_
    run command promt as administrator and type in sfc /scannow , this will bring your files back to default
    thx
    This has solved all my issues, all without the orb ^^
  3. #11
    Jun 2011
    10
    Post Thanks / Like
    4 Thread(s)
    Quote Originally Posted by Big V
    Yes, I ve done it correctly. I had to repatch the 3 .dll. I ve reinstalled Theme Resource Changer. When I start my computer, all issues have been fixed but not the problem with the start orb. However, I ve never modified the orb ...
  4. #12
    Big V is offline
    A Supreme God
    Feb 2010
    2,787
    Post Thanks / Like
    21 Post(s)
    296 Thread(s)
    Have you looked in the the theme resource folder and check to see if there is an orb included in the theme and that it is right format. There should be three images in that folder named 6801.png, 6805.png, and 6809.png these should be in a folder marked explorer.exe inside the resource folder
  5. #13
    Jun 2011
    10
    Post Thanks / Like
    4 Thread(s)
    Yes I have, I use fusion by lefty 1981. Folders with png are in the right place and with the right name. Orb works correctly when I reload the theme. My problem is that it doesn't work when I turn ON my computer...
    EDIT:
    So the only solution that I have found is to ask Lefty if he can gimme his "orb.bmp".
    I have patched my explorer.exe with it (even if I still use Theme Resource Changer ) and now all works great .
    Thanks for your help!
  1. How to use theme resource changer
    By razorsedge in forum Theme & Extras Setup Tutorials
    Last Post: 06-23-2014, 02:20 PM
  2. Replies: 18
    Last Post: 07-10-2012, 07:03 PM
  3. Make a theme use theme resource changer
    By gor17981 in forum Theme Building Questions
    Last Post: 03-09-2012, 03:10 PM
  4. Need Help with Theme Resource Changer
    By edee in forum Requests
    Last Post: 12-18-2011, 07:24 AM
  5. Task Manager Issue Please Help
    By mandy in forum Windows Style Builder v1.5 Tutorials
    Last Post: 10-12-2010, 11:49 AM
